Old 04-13-2014, 05:50 PM   #1
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
P13W drl question
I've been having issues with the leds continuously going out on my AAC P13w LEDs, after calling them they said I need to slice the power wire from the side marker to the drl? Did anyone else have to do this? Would it matter if I have the harness for the halos to run with the drls? Why should I have to splice it?
Airaid Intake And Solo CatBack Solo Highflow Cats
noisemker is offline   Reply With Quote
Old 04-16-2014, 08:32 PM   #2
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
no one has aftermarket drls?
Old 04-16-2014, 08:41 PM   #3
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Got mine from Offer, with the DRL harness. No problems, been about a year now.
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 04-17-2014, 09:30 AM   #4
upSSman
Do what now?
Drives: 2021 Wild Cherry 1LE
what do you mean, like intermittent power or simply going off when your headlights come on?
http://www.camaro5.com/forums/image.php?type=sigpic&userid=88434&dateline=139405  5577
upSSman is offline   Reply With Quote
Old 04-17-2014, 09:41 AM   #5
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
When you say you have leds going out on them, are you using SMD led bulbs like these:
or plasma bulbs like these:
If it's the top one, I would recommend switching to the bottom style. Get them from Diode Dynamics for the best price (about $30). Way better than the stuff AAC sells and they are nice guys too that stand behind their products.
You shouldn't need to slice or splice anything to make your DRL's work properly. I don't even know why AAC would recommend that, but sadly I have experienced similar bogus responses from them.
Deke736 is offline   Reply With Quote
Old 04-18-2014, 02:13 PM   #6
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
I am mistaken, I have the plasmas not the LEDs. I've been sent 3 different kinds one with a wire tail and connector and these two. One is white and one is black I don't know if there is any other differences. I'm being sent my 4th set now and am getting a little frustrated.
Old 04-18-2014, 03:10 PM   #7
Deke736
COTW 12/3/12
Deke736's Avatar
I don't blame you. I'd be pretty annoyed after several replacements too. If these don't work, I'd suggest cutting ties with AAC and find another vendor that is not only cheaper, but will be willing to help you get to the root cause.
Old 04-23-2014, 07:26 PM   #8
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
anyone else car to chime in on this even if you have the plasmas from AAC with no modifications need for install or no issues. Id like to install my new ones but dont want to do it until I know its done right. Please help!! i dont want to have to do this a 5th time
Old 05-04-2014, 08:43 PM   #9
markas214
markas214's Avatar
Drives: 2012 2SS/RS L99 SIM convertible
Arc does not stand behind their products. To me they are quite happy to gouge you once and not care about loyal customers. All of these less are pretty much junk. I've gone through two pairs of leds and gong to put my OEM back with a lens tint.
markas214 is offline   Reply With Quote
