Vararam
Old 07-20-2020, 02:36 PM   #1
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Is there a Grease Zerk on a 5th Gen Camaro?
I know I could probably look in the manual but are there ANY grease zerks/points to be found on our cars?
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 07-20-2020, 02:40 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
I was all over mine when it was on a lift, unless I missed something there are none to be found.
HOJO is offline   Reply With Quote
Old 07-20-2020, 03:06 PM   #3
Moto-Mojo
Moto-Mojo's Avatar
I was pretty sure that was the case. “Lubed for Life” is the modern way. (your mileage may vary)
Old 07-20-2020, 03:24 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I haven't seen a single one on this car.
InFiD3ViL is offline   Reply With Quote
Old 07-20-2020, 04:35 PM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
Not on factory parts.
Vegas Bound is offline   Reply With Quote
Old 07-20-2020, 07:11 PM   #6
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '20 Traverse Prem
"Lubed for Life"--the life of the joint, which is--unfortunately--foreshortened since it lacks proper lubrication!
RJT Impala is offline   Reply With Quote
Old 07-20-2020, 08:32 PM   #7
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
Can always add some
PeteD is offline   Reply With Quote
Old 07-21-2020, 07:21 PM   #8
Whoomba
Drives: 2024Camaro 2SS CE Convertible
Originally Posted by PeteD View Post
Can always add some
Didn’t see one on adding grease inserts. ADD. My 98 Chevy truck was that way.
Old 07-22-2020, 05:38 PM   #9
'10CamaroDude
Drives: 2010 Camaro LS
No Zerk fittings, and if there are, then an aftermarket part was installed. My Mevotech
LCAs have them.
'10CamaroDude is offline   Reply With Quote
Old 07-22-2020, 06:08 PM   #10
PeteD
PeteD's Avatar
You can add a zerk fitting to any part that is not solid. All it takes is the zerk, small drill bit and a tap. Then lube away
Old 07-22-2020, 09:52 PM   #11
Whoomba
Didn’t have to do that to the truck. The holes were there they just had bolts in them. I thought how much more could an insert cost than a bolt?
