Old 04-12-2020, 04:10 PM   #1
Whitlow
Whitlow's Avatar
Drives: Chevrolet Camaro
RAMPS INFO FOR OIL CHANGE
So what do y'all use to get your Camaro up to change oil? And not a car lift. What do you have and how much?
Thanks
Sent from my moto g(7) power using Tapatalk
Whitlow is offline   Reply With Quote
Old 04-12-2020, 04:29 PM   #2
Sinister10
Sinister10's Avatar
Drives: 2010 Camaro SS
a jack and jack stands
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs, SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC. SCTX4 and Dyno Steve tune.
Sinister10 is offline   Reply With Quote
Old 04-12-2020, 04:35 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Well, I was using ramps, but I don't think that's happening anymore. I lowered my car more this week and I can't even get a low profile jack under it unless I drive onto some 2x4s first.
InFiD3ViL is offline   Reply With Quote
Old 04-12-2020, 05:06 PM   #4
JRBumfuddle
Drives: '12 SS Silver Ice Metallic
3-ton floor jack, low profile. Jack stands. All from Harbor Freight. I've used them a lot and they have been great.
JRBumfuddle is offline   Reply With Quote
Old 04-12-2020, 05:08 PM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Rhyno ramps from walmart and now that its lowered some 2x10's to get into the ramp.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 04-12-2020, 05:12 PM   #6
Trickskier
Native Floridian
Trickskier's Avatar
I use Race Ramps 67” Long 10” High. They run about $350 but are well worth the money!
Old 04-12-2020, 05:33 PM   #7
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Rhino’s that just clear the GFX.
0stones0 is offline   Reply With Quote
Old 04-12-2020, 05:40 PM   #8
2011SSCT
2011SSCT's Avatar
Drives: 2011 Camaro 2SS/RS
Rhino Ramps. Got them at Autozone for either $39.99 or $49.99
L99 to LS3, Whipple 2.9 Blower with 3.750 pulley, ID1050x injectors, JRE Rough Idle Blower Cam, BTR Bronze Bushing Trunnion Kit , JRE/BTR .660 Springs, BTR Pushrods, Melling High Volume Oil Pump, ZL1 Fuel Pump, JRE FPCM, JMS BAP, JRE 90MM Ported Throttle Body Circle D 3200 Stall Converter, Ceramic Coated Kooks Long Tubes, Kooks Full Exhaust with Hi Flow Cats, Cold Air Inductions Intake With JRE Scoop, JRE Built Rear Differential with Billet Caps, 3:91 Gears and Eaton TrueTrac Posi, JRE Dyno Tune, Moroso Wires, Moroso Catch Can, Factory Reproductions Gloss Black ZL1 Wheels. 659WHP/566TQ
2011SSCT is offline   Reply With Quote
Old 04-12-2020, 06:16 PM   #9
BAH2SS
Stigs Bahraini Cousin
BAH2SS's Avatar
Drives: 2015 Camaro 2SS 1LE
I don't use ramps, maybe its an OCD thing not sure.
parking it angled will not drain totally.
2015 CAMARO 1LE
https://www.camaro5.com/forums/image.php?u=143224&type=sigpic&dateline=1541618573
BAH2SS is offline   Reply With Quote
Old 04-12-2020, 06:21 PM   #10
Greenhornet2
Yup that's pretty ocd lol. No need to worry about a few ounces of old oil. I knew a guy once who would start the engine for a couple seconds after the oil was drained to make sure he got all the oil out.... the amount of life he took off his cars was way more than the little bit of old oil left in the engine lol.
Old 04-12-2020, 06:34 PM   #11
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
My Z/28 has a pretty low snout so I use the ZL1 Addons Premium 3" Jack MagPad for lifting using the pinch weld location. About $41 ea or $131 for a set of 4. Place jack stands at sturdy sub-frame points and have at it.
ariZona28 is offline   Reply With Quote
Old 04-12-2020, 06:37 PM   #12
BAH2SS
BAH2SS's Avatar
Ok so how many inches would i need to get ?
https://www.amazon.com/RhinoGear-119.../dp/B0117EETEK
https://www.summitracing.com/int/parts/bti-rr-40
2015 CAMARO 1LE
Old 04-12-2020, 07:25 PM   #13
spyderbuddy
spyderbuddy's Avatar
Drives: 2010 RS Inferno Orange Metallic
ditto
p.s. the oil drain is to the passenger rear so oil drains fine
I only have to get the drivers side up high enough to get under the car with jack stands
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
spyderbuddy is offline   Reply With Quote
Old 04-12-2020, 07:35 PM   #14
Whitlow
Whitlow's Avatar
I can't get any regular ramps to work even the ones I had for my 77vette won't work. My SLP is lowered 1" front and back. But I'm not taking it in for oil change for someone to take it out for a joy ride.
