04-22-2024, 10:20 AM | #225 | |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
04-22-2024, 10:33 AM | #226 |
Drives: 2017 Camaro ZL1 Join Date: Feb 2024
Stop at 850??
Who are you kidding?? |
04-22-2024, 12:55 PM | #227 |
I for one don't like to run hardware at or very near its maximum capability/capacity, so I would definitely not try to push a small blower and "see how far it can go". Every component has a sweet spot or a band where you can get the best blend of power, efficiency and longevity, so even if nothing bad happens to that 1.7-liter unit right off the bat, to me this feels like rolling the dice again and again.
05-05-2024, 08:12 PM | #228 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
GESI UHO 850hp Cats Have Arrived
3" In and Out 4.5" Diameter 7" Long 3.15 Pounds Each Having them installed with V.Bands tomorrow... More to follow
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
05-06-2024, 07:21 AM | #229 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
While just doing my oil change on the lift I found my cats were shot. I bought the ARH headers with their cats and they were gone (rattling) in 5k miles. I replaced them with GESI high flow cats. I also decided to go back to the NPP exhaust as the AWE Touring axle backs were just too loud. What I found out is the Kong Xport I did with the WeaponX lid allows the whine sound to really be heard, especially in touring mode. So for now I feel like I have what I was really looking for in a build. Good luck going forward.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
05-06-2024, 07:36 AM | #230 |
What is your enrichment lambda and is COT turned on?
If so is your cot set to stock values?
05-06-2024, 08:31 AM | #231 | |
COT was turned off after I gutted the ARH cats. I will re-evaluate the COT values after I talk with my tuner.
05-06-2024, 10:16 AM | #232 | |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
2023 ZL1 Auto - CSP 2" Long Tubes by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port | Griptech 2.3" Upper | ATI Super Damper 15% / 9.45" Lower | TooHigh PSI Port Injection w/875cc Injectors | E85 | Granatelli Malevolent Coil Packs | Katech Low Profile Billet Valve Covers | Katech Duel Fuel Pump System | Mighty Mouse 1000 | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | Katech Tuned
05-06-2024, 11:06 AM | #233 |
HAHA, yes they do! Wish I would have started with these, but I dont think they were out at that time...
05-07-2024, 03:00 PM | #234 |
Received on Friday... Installed on Monday... Car is back to having that deep mean tone... 15% less volume... 75% less smell... and a set of off-road pipes that can be easily swapped for dyno / race days...
The only downside is slightly reduced ground clearance. As the V band hangs about .25" lower than the collector. Working on a quick video to share.
05-07-2024, 04:22 PM | #235 |
Drives: ‘23 ZL1-1LE Join Date: Mar 2023
Looks like your cats are the low point anyway, maybe it’s the camera angle….. properly installed V-bands are the way to go. The hardest part is insuring the flanges don’t warp during the welding process. I’ve found over the years that the machined flange v-bands are most likely to leak vs. the formed flanges.
05-07-2024, 04:22 PM | #236 |
Sarcasm loading --------
This may have been covered already, but on those cats is that 850 total or 850 per cat?
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
05-07-2024, 05:02 PM | #237 | |
Correct.... 850hp per cat
