Old 10-20-2013, 06:46 PM   #1
elarson5757
Obsessed and Loving It...
Drives: 2013 1LE-SS
elarson5757's Upcoming Livernois Build
OK..time to lay out the winter engine build up!! I have been working with Andy Ricketts over at Livernois in Metro Detroit. Frankly they are the ONLY company in Michigan I want doing this. They have an amazing reputation, unbelievable shop, and have hundreds, maybe thousands of cars under their belt.
Andy if you see this feel free to weigh in!!
Here is the plan. Clearly it will include before/after dyno testing and as many pics and videos as I can talk Andy and his team into taking! My intentions is to have them pick it up for these upgrades after the first of the year as the car will be stored anyway.
-Whipple 2.9 Supercharger
-RotoFab intake (have CAI now but Andy is suggesting better flow at these HP with RotoFab)
-Kooks Long Tube Headers w/Hi Flow Cats
-Corsa Exhaust
-Livernois 2C Hi Lift Blower Cam
-Livernois Stage 2 Heads
-McLeod RTX Twin Disk Clutch/Aluminum Flywheel
-Livernois Dual Fuel Pump Setup
-MSD Plug Wires
-NGK TR6 Plugs
-ARP Cam Bolts
-7.425" 5/16" Pushrods
-ARP Head Bolts
-LS9 Head Gasket
-ARP Flywheel bolts
-BMR Trailing Arms
-DSS 1000HP Axles
-Boost and AFR Gauges with A-Pillar Mount
Andy is expecting between 680-700HP to the rear wheels....should be a BEAST!!! In their opinion this is a safe and reliable combination all be it the top end of the range on the stock bottom end. If I get bored with this after time a forged bottom end from Livernois will be the next step along with bumping up the boost.
The wait for spring will kill me.... More to follow after the first of the year....
elarson5757 is offline   Reply With Quote
Old 10-21-2013, 07:53 PM   #2
jrpxxii
jrpxxii's Avatar
Drives: 2010 Camaro SS/RS 427ci
All looks good as this is the most common first steps for people doing a build like this. Depending on how hard you are going to use the car will tell how long it will last before it needs to be forged. I would suggest solid cradle bushings and lca's to the build as the rear suspension is very critical to get these cars to hookup especially with a manual.
jrpxxii is offline   Reply With Quote
Old 10-24-2013, 07:39 AM   #3
Mamooth
Drives: 2012 2SS/RS 6M
Fantastic, man good luck! Livernois is really great to work with, I just picked my SS from them a couple weeks back.
Your project looks exactly like what I want to finish out as on my car, fine plan, sir
Looking forward to updates.
Mamooth is offline   Reply With Quote
Old 10-24-2013, 04:37 PM   #4
elarson5757
Drives: 2013 1LE-SS
Don't know your name but you may be the similar plans build Andy referenced that had just been picked up.
