Vararam
Old 01-16-2019, 08:47 PM   #1
Xmetal
Drives: 2014 LS RIP
BMR frame connector issue
I’ve had my frame connectors for two years on my ‘14. I was under the car last week and they are rusting really bad!!! Anyone else having this problem?
Xmetal is offline   Reply With Quote
Old 01-16-2019, 09:51 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Salt up there?
Vegas Bound is offline   Reply With Quote
Old 01-16-2019, 10:01 PM   #3
05SilverStreak
05SilverStreak's Avatar
Drives: Black aSS 2011 - L99
Remove, sand repaint?
Staying stock and loving it............
05SilverStreak is offline   Reply With Quote
Old 01-16-2019, 10:03 PM   #4
Vegas Bound
Wow, rarest Camaro on Earth. Congrats.
Old 01-17-2019, 12:34 AM   #5
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I'm not going to lie. I am very confused.
InFiD3ViL is offline   Reply With Quote
Old 01-17-2019, 07:17 AM   #6
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
The used ones that I bought were starting to rust pretty badly when I got them.
gtstorey is offline   Reply With Quote
Old 01-17-2019, 07:29 AM   #7
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
Strip them and have them powder coated.
ZEN357 is offline   Reply With Quote
Old 01-17-2019, 08:06 AM   #8
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
I thought they powder coated all their products? My trailing arms are powder coated...
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 01-17-2019, 10:39 AM   #9
BMR Sales
BMR Sales's Avatar
Drives: Race Car
They are Powdercoated, but they are made of Mild Steel so the Elements & plus snow removal solutions - Salt, Salt Brine, Liquid Magnesium Chloride, potassium acetate can take their toll.
Old 01-17-2019, 11:45 AM   #10
Terryfied
Terryfied's Avatar
Drives: 2010 2SS L99
That's why I'm a fan of the "aluminum" Hotchkis Max Chassis Brace.
Terryfied is offline   Reply With Quote
Old 01-17-2019, 08:23 PM   #11
Xmetal
Drives: 2014 LS RIP
There is salt up here, BUT my car doesn’t go out in the winter!
Old 01-17-2019, 08:24 PM   #12
Xmetal
Drives: 2014 LS RIP
It’s a shame I like BMR products but even my strut brace is starting to peel.
Old 01-17-2019, 11:12 PM   #13
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
All materials are prone to corrosion.
Of course you have atmospheric conditions like salt (which is ever present in Maine, not only in winter) but elements not often considered because they are so common, such as moisture, dirt, pollen, etc.
Heat and cold affect materials with changes in dimensions. Coatings don't always change dimensions at the same rate as the material they are applied to.
Probably the best material today, as it has been for many years, is stainless steel, as far as corrosion. But it is heavy and difficult to work with and expensive.
It is all a trade-off in cost. How many people will pay 10X as much for a chassis brace that will last forever instead of something that will last as long as you need it?
If you don't think aluminum corrodes you have another think coming. Aluminum corrodes quickly in water alone.
And if you probe a bit deeper you should investigate fatigue, which is why airplanes are junked after a number of hours of use and you will never find a permanent building on an aluminum frame.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 01-18-2019, 10:41 AM   #14
Terryfied
Terryfied's Avatar
And if you probe a bit deeper you should investigate fatigue, which is why airplanes are junked after a number of hours of use and you will never find a permanent building on an aluminum frame.[/QUOTE]
You're absolutely right that aluminum corrodes by oxydation but after a thin layer of aluminum oxide forms it typically halts further corrosion unlike rust. Besides, the Hotchkis brace is light and I'll take my chances with regard to fatigue. I haven't bought it yet but it's next on my list.
