Old 09-05-2022, 07:03 AM   #1
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
Touch screen not working
2019 3LT - I have already done the F16 fuse pull with no luck. I have this issue every now and then where the touch screen just stops functioning. The screen stays on, it's lit up and the songs will update, etc... but the touch function doesn't work whatsoever, and the buttons under the radio don't work either.
Volume can only be adjusted from the steering wheel, and the screen display can be changed from there as well. Any help would be appreciated!
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
Black on black 2019 3LT RS Camaro.
1100: 3/7/19 | 4200: 4/15/19
3100: 3/15/19 | 4800: 4/23/19
3400: 3/22/19 | 5000: 4/25/19
Built: 4/8/19 | Home: 4/26/19
RideWithDanger is offline   Reply With Quote
Old 10-26-2022, 09:08 AM   #2
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
Something similar going on with mine- any update?
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
5th_GEN_SS is offline   Reply With Quote
Old 10-26-2022, 12:48 PM   #3
Callaway SC630
Callaway SC630's Avatar
Drives: 2020 Callaway Camaro SC630
Try number 55 as well.
As one person tried, they pulled and reinserted all fuses in the rear box and that fixed the problem.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue
Callaway SC630 is offline   Reply With Quote
