04-24-2024, 02:50 PM | #1 |
Can someone tell me what these are? (ZL1 Alternator Generator Splash Shield)
As the title says, I have no idea what these are, or do. I ask because I am nearly done piecing together everything needed for my ZL1 front bumper conversion (5th gen style, not 6th gen).
I already have pretty much everything else for the conversion, some of it not necessary, but I really wanted the complete look. I have the complete basic kit...bumper, fog lights and bezels, brackets, ZL1 grill (might still use my Heritage grill), splitter, and bolt and plastic rivets kits, etc... I also bought ZL1 wheel well liners and decided to splurge on the ridiculously expensive OEM front ZL1 splash shields ($240, really??), which arrived today. I know a lot of the is not needed and optional. Not sure which direction I am going with the hood yet. But for the life of me, I can't figure out what these things are for or do. I am guessing they are part of the brake duct setup and maybe attached to the wheel well liners? All the diagrams I find are are the parts explosion diagram type, which makes it hard to visualize. I may also post this in the ZL1 forums, but that place is a ghost town. Thanks guys! https://www.ebay.com/itm/265621496410
04-24-2024, 03:49 PM | #2 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
On your eBay link, it does say what they are.. just saying.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-24-2024, 04:22 PM | #3 | |
Edit: Alright, I found the GM ZL1 brake duct installation instructions and these are not pictured or mentioned anywhere. So I am good in that regard. Bad news, the brake duct kit has been discontinued for since forever. Anyhow, nothing to see here folks, just an idiot with diminishing online search skills!
04-24-2024, 04:46 PM | #4 |
Happens to the best of us.
04-24-2024, 06:00 PM | #5 |
Drives: 2013 ZL1 Join Date: Sep 2021
The brake ducts have been discontinued for a while now-you would be very lucky to find a set. My left one has a small crack in it that no one would ever see, but it drives me crazy to know its there-been looking for one for a while.
04-24-2024, 06:16 PM | #6 | |
Just sucks for those of you that already have them and need to replace something. 3D printing is always an option to replace or repair I guess.
04-25-2024, 02:19 AM | #7 | |
1000hp is NEVER Enough!
These 2 pieces are the inner fender close outs from the frame to the front sub-frame inboard of the front struts. They are installed with push pins. They keep road debris kicked up by the tires from entering the engine bay.
1,000hp IS NEVER ENOUGH!!!
04-25-2024, 06:32 AM | #8 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
I thought all Camaros used the splash shields from 2012-15. So you may or may not need them on a 2010? I dunno. I put the entire ZL1 front end setup on our 2010 back in 2014 and I don't recall buying or using those.
And those air ducts are CHEAP ass plastic that are basically 2 halves that sloppily clip together IIRC. They feel flimsy and gimmicky. But they do work to a degree.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
04-25-2024, 09:45 AM | #9 |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
I have the left side air duct if ya need it.
04-25-2024, 07:24 PM | #10 |
Awesome man, thank you so much! They are fairly inexpensive, so I may just get them since I also got the ZL1 liners.
