Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 09-20-2013, 09:57 AM   #1
GeorgeM
Drives: 2016 2SS, Yellowjacket, A8
How often do you change spark plugs?
I was wondering how frequently you change your spark plugs. I have a 2010 SS with only 15,000 mi and wonder if I should replace the plugs.
The manual says you don't need to replace them, but I don't buy into that.
GeorgeM
GeorgeM is offline   Reply With Quote
Old 09-20-2013, 10:00 AM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I haven't changed mine with 21K on it. Just pull one and see how it looks ..
SlingShot is offline   Reply With Quote
Old 09-20-2013, 10:01 AM   #3
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Depends on what you do... I change mine monthly due to nitrous passes and just my driving. But if it's stock id say every 30k. Cheap maintenance to just replace occasionally
Gtkilrss is offline   Reply With Quote
Old 09-20-2013, 10:02 AM   #4
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
They are 100k-mile Iridium spark plugs. The tips never wear.
Unless you're modified and racing the car every weekend, fuhgetabouddit.
Bye bye, Bumblebee!
strych9 is offline   Reply With Quote
Old 09-20-2013, 10:14 AM   #5
40years
40years's Avatar
Drives: 2016 CAMARO 1SS Hyper Blue Met.
Over 42,000 miles and mine look brand new.
proud member "club elite" # 89
40years is offline   Reply With Quote
Old 09-20-2013, 11:00 AM   #6
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
I changed the plugs on my modded SS at 75,000 miles only because I felt like it. Old plugs still looked like new.
mrvenicess is offline   Reply With Quote
Old 09-20-2013, 11:34 AM   #7
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
How long will I get on my points condenser and rotor?
tramtwo is offline   Reply With Quote
Old 09-20-2013, 11:36 AM   #8
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Look at the plugs at 100K, and make a decision. Do not worry before then unless you have modded the engine or are sparying it.
gajagfan is offline   Reply With Quote
Old 09-20-2013, 11:40 AM   #9
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
old school
How about distributor cap? And check your dwell while your at it. Lol
Sikoriko is offline   Reply With Quote
Old 09-20-2013, 12:38 PM   #10
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
Don't waste your money, if you are basically stock, 7 years or 100k. The stock plugs last forever.
On our boosted builds we upgrade to the ZR1 plug and recommend at 50k, with no issues, still look like new.
Piccione Performance is offline   Reply With Quote
Old 09-20-2013, 12:53 PM   #11
TastyBake
TastyBake's Avatar
Drives: 2011 Camaro 2LT/RS Black
+1
These aren't the same plugs back in the day where your car needed a tune-up every 20k.
These are 100k plugs. But how do you change them? I assume like a standard plug change.
TastyBake is offline   Reply With Quote
Old 09-21-2013, 11:37 AM   #12
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I had 57K miles on mine last November when I had to change valve springs and rocker trunnions due to a trunnion failure. Since I had to remove the plugs to effect the spring change, I went ahead and installed some iridium plugs. There was slight visible wear and gap growth on the original stock plugs.
If you are concerned about plugs, take them out for inspection. They should all look the same and have a light sandy color to them and the gap should be around .035 to .040. Someone can verify the gap if I am wrong. If the positive electrode is rounding off at all then I would consider changing. If they still have a defined edge they should be OK. Also look close at the ceramic parts to see if there are any cracks or damage. A magnifying glass helps with this part. Make sure your wires seat fully on the plug and coil when you are done too.
Edit: If you think a plug is bad and change it, change them all so you have equal spark energy to all cylinders. As for the higher cost of iridium plugs, I am confident they will last longer than most since iridium is very, very hard and resistant to wear. With the thinner electrode they also have less chance to round off and they focus a tighter spark where it needs to be rather than arcing to one side of a typical worn plug.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 09-24-2013, 08:44 AM   #13
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
around 70,000 miles is recommended. only use the same ACDelco plugs put in from the factory.
Old 09-24-2013, 10:51 AM   #14
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Ngk tr55 great replacement :cheers:
