Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 11-21-2018, 01:15 AM   #1
Rami ZL1
Drives: 2013 Camaro ZL1 Manual
Weight reduction for ZL1
When it comes to HP Camaro is easy to hit the 700s
yet weight is our huge down side.
I have seen many posts earlier about weight reduction. some ideas were realistic like removing the unwanted seats, interior of the trunk, lower weight rotors etc...
Some other ideas were crazy especially removing bumpers steel reinforcement and airbags which basically means getting ourselves into a moving coffin.
Let us please share some realistic/safe ideas of weight reduction. on the end it all depends on your usage of the vehicle.
I would start with:
- Removing passenger and back seat.
- Replacing driver seat with low weight sports seats.
- Removing trunk interior.
- Weld wheels
- LTH instead of cats and manifolds
- If you are in a cold region you can remove the A/C compressor
- Audio system
- half fuel tank on race/event
- reduce your own weight
Manual 2013 ZL1 - Kooks LTH, JLT CAI, Nick Williams 102mm TB with 107mm spacer, Weapon X S/C spacer, 10" Crank pulley, 2.7" supercharger pulley, ZR1 cam shaft, Alky methanol kit, AFCO heat exchanger.
725 WHP - 730 TQ
Boost 16.5 PSI
Rami ZL1 is offline   Reply With Quote
Old 11-21-2018, 04:01 AM   #2
Brutale arancia
Brutale arancia's Avatar
Drives: 2013 ZL1 Camaro
Replace the V8 with a four cylinder engine, magnetic ride with cheap shocks, skinny wheels and tires, remove the cf hood insert so you can see that sweet looking four banger!
Brutale arancia is offline   Reply With Quote
Old 11-21-2018, 11:09 PM   #3
Rami ZL1
Hahahah 4 cylinders !!!
The day there is a 4 cylinders Camaro I will send ZL1 for a deep water dive
725 WHP - 730 TQ
Boost 16.5 PSI
Old 11-22-2018, 04:20 AM   #4
Brutale arancia
Just goofin' after a few shots of Grand Marnier. I like the way it feels like it's square from the drivers seat, demands spatial awareness. I think if it weighed 3000 pounds it would be less thrilling to toss it into a turn at twice the recommended speed. Super cool car!
Old 11-23-2018, 05:57 PM   #5
Matt8892(2)
Drives: Black camaro 2ss 45th
Get sendin. There have been 4 cylinder camaros since the 6th gens debuted
Matt8892(2) is offline   Reply With Quote
Old 11-23-2018, 06:26 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
Yep a Vendor here drags them into the 10s too...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 11-23-2018, 10:24 PM   #7
Azzkker
Azzkker's Avatar
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z
Must of forgot about the iron Duke 4 cyl 3rd gen.
Azzkker is offline   Reply With Quote
weight
