10-27-2017, 07:41 AM | #1 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Oil Composition, Direct Injection, & Low-Speed Knock article
Something i thought some of you who might invest in tuning in the future would benefit from reading. Also may help some of you performance wise, especially in lower rpm ranges (off the line)
http://www.enginelabs.com/engine-tec...w-speed-knock/
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
10-27-2017, 08:49 AM | #2 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Great info thanks!
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
10-27-2017, 09:33 AM | #3 |
Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
Very nice hopefully they release some more detailed results on Brands etc...
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/ Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA Supercharged with Overkill Superchargers http://www.v6superchargers.com |
10-27-2017, 02:07 PM | #4 |
Drives: 2010 Camaro Join Date: Nov 2009
This is info we have been sharing for app a year now in our technical posts. Piston failure when LSPI occurs is one of the # one failures GDI engine experience, and turbo charged are more prone. Oil mist mixed with fuel introduced at 2000-3000 PSI gets behind the rings and the resulting detonation is powerful enough to break the piston generally at the top ring land. The LLT and LFX as well as Ford Ecoboost and many other makes (GM 2.0T early versions in the Caddy ATS were horrible for this, GM replaced pistons with thicker construction for the Camaro) and Amsoil recently released their new Signature Series and all street blends with a new formulation that greatly reduces this by rendering the mixture non-explosive. Our dual valve full time evacuation systems also have been removing these vapors before they can reach levels of causing this as well.
Great info, keep up the research Nui! Education about these engines most assume are no different than the past port injection ones is so needed. This is another era and you cannot just follow the owners manual or misinformed dealers direction on maintenance. You must take steps and get involved again in the care of your engine as in "the old days". |
10-27-2017, 07:09 PM | #5 |
Most of the information that is posted is pretty technical and goes over most peoples heads, I feel this article helps bring the explanation a bit more on the level of the common car enthusiast. I definitely enjoyed reading it.
10-27-2017, 08:11 PM | #6 |
Drives: 2014 Stingray, 2017 Cadillac XT5 Join Date: Jun 2017
Very interesting article and I look forward to the next chapter in their testing.
This one paragraph explains the issue very well: “It has nothing to do with the amount of oil in the combustion chamber, or if the engine is consuming oil or not. There’s going to be oil in the upper ring zone in every properly lubricated engine. It’s a question of whether the oil in the upper ring zone has a tendency to hold fuel, or not. If the fuel mixes with the oil, and the oil creates an emulsion, if you will, where it holds the fuel in the oil, that’s where things can begin to go bad,” says Speed. Leading up to this statement, there is another influence in the amount of splash on the cylinder walls under the pistons. The test is being conducted on a GM LT1 which the majority can identify with directly. |
10-30-2017, 12:33 PM | #7 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Good read, but wish there was a conclusion to go with it.
I'm left with the question: So which oil should I be buying? A few years back, when I still owned my 2010 V6 with the LLT, I had done a lot of reading on a similar subject seeing as how at times an LLT would pop for apparently no reason, and saw posts and evidence showing that the high end Pennzoil Platinum oil was a good choice for these engines. That's what I'm still running today. I see that Elite says "Amsoil Signature" is a good choice. Anyone else have an insight?
2010 Camaro 1LT V6 (Sold. I will miss her!) |
10-30-2017, 02:15 PM | #8 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
ILSAC GF-6 and Dexos1 oil post-2015 are oil formulations that directly try and work to reduce stochastic pre-ignition.
So pick an oil that meets those specs and you'll be as best prepared to avoid this predetonation issue as possible. |
10-30-2017, 04:54 PM | #9 |
Amsoil recently released a new formulation of all of their street use oils that render those vapors non-explosive. So far in their testing (and they do extensive testing) it has eliminated most or all of this issue. M1 may be following as well with a new formulation. Of course a proper dual valve catchcan system that pulls evacuation at all times will eliminate most of this as well as it is constantly flushing and evacuating all vapors from the crankcase.
10-31-2017, 04:03 PM | #10 | |
Late EDIT: The Amsoil signature series also shows ILSAC GF-5 spec, but specifically mentions protection from pre-ignition, while the Pennzoil does not, although I guess that doesn't mean it does not provide that protection. Ehhh...who knows lol. Pennzoil PlatinumŪ Full Synthetic Motor Oil with PurePlusŪ Technology Industry specifications: ◾API SN, SM, SL and SJ ◾ACEA A1/B1-10, A1/B1-12 and ACEA A5/B5-10, A5/B5-12 (SAE 5W-30) ◾ILSAC GF-5 ◾Exceeds ILSAC GF-5 engine cleansing and protection requirements OEM specifications: ◾Chrysler MS-6395 (SAE 0W-20, SAE 5W-20, SAE 5W-30, SAE 10W-30) ◾Ford WSS-M2C930-A and WSS-M2C945-A (SAE 5W-20) ◾Ford WSS-M2C929-A and WSS-M2C946-A (SAE 5W-30) ◾Ford WSS-M2C947-A (SAE 0W-20) ◾GM 6094M (SAE 5W-20, SAE 5W-30, SAE 10W-30) ◾GM 4718M (Corvette and Cadillac) (SAE 5W-30, SAE 10W-30) ◾GM dexos1™ Certification (SAE 0W-20, SAE 5W-20, SAE 5W-30) ◾Honda/Acura HTO-06 (SAE 5W-30) ◾Volvo (SAE 5W-30) Specifications may vary by viscosity grade. Beginning with its 2011 model year vehicles, GM began recommending oils meeting the GM dexos1™ oil performance level for for all gasoline engine vehicles. Pennzoil PlatinumŪ 5W-30 Full Synthetic Motor Oil exceeds GM dexos1™ specifications. These specifications are to be used as guidelines only. Please refer to your individual vehicle owner's manual for proper viscosity grade and specification of oil to use.
10-31-2017, 05:30 PM | #11 | |
for info on GF-6....which is specifically designed to eliminate this problem https://passenger.lubrizoladditives3...ications/gf-6/ It seems actually labeling the GF-6 standard on oil is not being done yet. However, this doesn't mean oil companies aren't putting out oil now that meets it (particularly those that "exceed GF-5"). edit: in lieu of having GF-6 labeled oil and not being sure if you're using dexos1 gen1 or gen 2 (gen 2 is good) then we can just go to the manufacturers directly. It looks like Amsoil upgraded all their full synth oils to not include the problem additive so you can basically pick any of the signature series and be fine. They even advertise 100% protection against it. Pennzoil full synth is also good. It exceeds the dexos1 gen2 spec. https://noln.net/2016/05/06/pennzoil...2015-approval/ So with the lineup of full synth from amsoil and pennzoil covered, that should take care of most people. Mobil1 is probably also good these days as far as lspi. So as long as you've been either doing your own oil changes or ensuring that these oils are being used when you have your oil changed by someone else, you should be golden. Blended oils can also be acceptable, however I expect anyone who is using blended oils vs full synth probably doesn't care enough about their oil anyway to bother reading a forum about it. Last edited by cellsafemode; 10-31-2017 at 05:53 PM. |
