10-25-2016, 09:58 AM | #15 |
Drives: Camaro V6 Join Date: Oct 2016
Nice plan, but I think that is still illegal too. Got to have the real plate up front, I believe.
10-26-2016, 05:23 PM | #16 |
Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT Join Date: Sep 2016
Can anyone explain in greater detail how to drill the rivets out? I tried taking a drill through the center of the rivet, and it went all the way through, but did not release. Do I use a larger-diameter drill bit, and drill the head off? I'm afraid I've probably damaged the facia even more now.
10-26-2016, 05:24 PM | #17 |
and yes, the pics are upside down, grr.
10-26-2016, 06:55 PM | #18 |
OK, to answer my own question, I took a bigger bit and drilled out the head. Wish I would have just done that, as the rivets would have probably filled the holes rather well. Still not happy, but I I'll probably borrow a dremel and cut off the small pieces of rivet protruding from the holes, and call it a day. If you're not looking for it, you don't see it. . .
10-26-2016, 06:56 PM | #19 |
guess I should learn this, how do I flip the pics? I have a Samsung S5. . .
10-27-2016, 07:20 PM | #20 |
Drives: 16 Camaro 2SS Join Date: Aug 2016
Gonna take mine off this weekend. Dealer put the bracket on my car as well :(
07-23-2018, 12:30 PM | #21 |
Drives: 2017 1SS Blue Join Date: Mar 2010
Any videos out there? how many rivets?
07-23-2018, 01:52 PM | #22 |
Drives: 2016 2SS Convertible Join Date: May 2012
If the plate was installed correctly there should only be two rivets at the top of the lower grill:
07-24-2018, 05:40 AM | #23 |
Drives: 18 2SS A8 Join Date: Jun 2018
I live in a one plate state but bought the car in a two plate state. I must have told the dealer a dozen times not to install the front plate. I’m sure he thought I was nuts. Happily, no front plate bracket installed.
07-24-2018, 12:25 PM | #24 |
If you don't like the bumper plug idea, you might get an acceptable result using a hot glue gun to fill the holes then trimming flush with a razor blade. Use a black glue stick.
The glue gun sticks are polypropylene. Bumper covers are usually EPDM, which is PP with a stiffener. |
07-29-2018, 01:08 AM | #25 |
Success! All that remains are two 7/32 holes that are not noticeable. Not even worth plugging.
07-29-2018, 02:19 AM | #26 |
Drives: camaro Join Date: Jul 2018
never put this on
06-24-2019, 04:36 PM | #27 | |
Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
06-24-2019, 06:04 PM | #28 |
SS Copbait R.I.
Drives: 2016 Camaro 2SS Join Date: Dec 2016
https://www.camaro6.com/forums/showt...=515295&page=2 see post #18 I believe many of us, including myself used a 3/16 to drill through. I never plugged mine as they are hardly noticeable. Just take your time. |
