07-01-2016, 08:26 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Range device users
I am wondering if this will keep the forward AFM valves open 100% of the time. The car sounds so much better at an idle when those valves are open the first 30 seconds after a cold start. Then they close and dampen the exhuast note even if the fuse is pulled on the rear NPP valves.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
07-01-2016, 08:29 PM | #2 |
Retired from Car mfrs....
Yes, it kills AFM......completely
07-01-2016, 08:35 PM | #3 |
Thank you for the response
07-01-2016, 09:47 PM | #4 |
Drives: 2015 Porsche BGTS, 2016 2SS Join Date: Oct 2013
Yes, it will kill AFM but I'm pretty sure the AFM valves aren't closing after the motor starts up. It gets quieter because it comes off high idle. If it is the AFM valves closing its not in response to AFM because the car never goes into V4 mode at idle. I can confirm the car is no louder with the range device installed, I have one that we don't use because AFM in the LT1 works light years better than it did on the Gen 5 but when it was installed the car still quieted down as it came of high idle.
07-01-2016, 09:56 PM | #5 | |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
07-01-2016, 10:08 PM | #6 |
Drives: 2023 ZL1 Convertible, 1998 Z28 Join Date: Jan 2013
I have had the same experience.
2023 Rapid Blue ZL1 Convertible
07-01-2016, 10:14 PM | #7 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Don't bother with a Range device on the LT1, I have one with the latest FW version, even verified it with the company, keeps throwing CELs, not worth the hassle.
07-02-2016, 12:08 PM | #8 |
Agree with everyone else...AFM valves only close in V4 mode when crusing. NPP will go fully open on cold start then close up which is what you hear. Also not sure if everyone knows this but if I'm driving in Manual shift mode AFM will not engage regardless of drive mode or speed.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
07-05-2016, 08:39 PM | #9 |
NPP fuse is pulled and on a cold start after about 30 seconds the volume of the exhaust note changes VERY noticeably. Id have a hard time believing its simply coming off high idle. It sure sounds like something mechanical happens to me.
07-05-2016, 08:49 PM | #10 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Guessing you mean the performance exhaust which is from my experience open on start up. The exhaust valves close quickly quieting the exhaust.
This has nothing to do with exhaust valves, which by the way should NEVER stay open 100% of the time unless you want a massive destructive collision with a piston..........which is bad.
07-05-2016, 09:01 PM | #11 |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
To add, all cars get quieter after initial startup. Most of the time it's the CATS warming up, but also just in general the exhaust warming up too. My '69 Mustang is much louder on start up.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
07-05-2016, 10:50 PM | #12 | |
When it is colder out you may notice it to be even louder as more timing is pulled during a cold start. Once the engine temp starts to rise you notice it start to come off high idle and the ECU adds more timing, which affects the exhaust note.
07-06-2016, 12:11 AM | #13 | |
Drives: 2016 Camaro 2SS Join Date: May 2016
Have you logged timing to verify this? Engines are more efficient with more timing advance, to a degree...(no pun intended)
07-06-2016, 12:33 AM | #14 |
Exactly. My '69 runs louder and better mpg with more timing.
