TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 10-22-2017, 08:42 PM   #1
smokum
smokum's Avatar
Drives: 2010 2ssrs
Alternator issues
All of a sudden I had to replace my alternator. No biggie. Other than I am now on the 3rd one in a month. Bought from oreileys auto parts. Put them in and they are good to start then the stop charging and battery goes dead. Had the battery checked 3 times in and out of the car. Any ideas were to start on this problem. Thanks
smokum is offline   Reply With Quote
Old 10-23-2017, 08:42 AM   #2
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
Check your grounds
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
briancamaross is offline   Reply With Quote
Old 10-23-2017, 08:50 AM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
do they test the alt before replacin it? any mods to car? too many q's...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 10-23-2017, 04:31 PM   #4
smokum
smokum's Avatar
Drives: 2010 2ssrs
Grounds nd cables all good. Never had one issue ever till alternator took a dump. Alternators all tested good at the store. But who knows.
Old 10-24-2017, 11:48 PM   #5
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
GMs adaptive charging ... charges when it senses the need... I wonder if that may be part of it... built into the alternator I believe. Would want to be sure it know it needs to charge...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 10-25-2017, 05:03 AM   #6
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
What makes you say they stopped charging ?
camguynj is online now   Reply With Quote
Old 10-26-2017, 02:08 PM   #7
smokum
smokum's Avatar
Drives: 2010 2ssrs
Yes hammdo adaptive charging. Goes to 15 v to 12 volts as needed. But then it goes to 12-11-10-9-8 and the car dies. They just take a shit. Two things that make it work. First a good battery. Checked 3 times. Gm battery 1 year old. Checks perfect each time. Second good alternator. On the 3rd one. Only thing the car has is a shitload of hp. No stereo or any other electronics. If the battery just drained I would say something else is drawing juice somewhere. But it can be charged sit for 3 weeks and start right up. I'm thinking whatever tells the adaptive charging to work has something to do with it or just 3 week alternator. Maybe I will just buy a new gm one and start fresh.
Old 10-26-2017, 06:59 PM   #8
oslouie
oslouie's Avatar
Drives: 2018 2SS M6 Redline
Are they new or refurbed? Refurbished alts tend to have high failure rates from my experience of having had worked for O'Reilly's.
oslouie is offline   Reply With Quote
Old 10-26-2017, 07:21 PM   #9
smokum
smokum's Avatar
Drives: 2010 2ssrs
It's a refurb. I'm going to return it again and get a new gm one.
Old 10-26-2017, 07:45 PM   #10
hammdo
hammdo's Avatar
Sure sounds Like the adaptive is not sensing correctly. New may help...don’t know if the manual has a check for it or, if the tech 2 would help...
-Don
747 RWHP 794 RWTQ
Old 10-26-2017, 08:15 PM   #11
camguynj
camguynj's Avatar
Are you running the stock underdrive pulley or did you replace it ?
Old 10-27-2017, 11:54 AM   #12
smokum
smokum's Avatar
Drives: 2010 2ssrs
Yes same stock pulley.
Old 12-24-2017, 04:38 PM   #13
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
Did you ever resolve this problem?
Im having the same issue. I have the battery fully charged up with a trickle charger. its less than a year old Interstate battery. Brand new OEM alternator. starts, drives, service charging system warning. I can drive for about an hour tops. volts slowly dropping the whole time. until the car just turns everything off and then eventually the motor dies, battery dead.
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 01-13-2018, 04:48 PM   #14
smokum
smokum's Avatar
Drives: 2010 2ssrs
Not yet. Has been sitting in storage. Have not have time to look into it yet. Starting to piss me off. Car is perfect other than this stupid issue. Never had a problem what so ever till this. Pulling alternator out again this weekend to see what's wrong with it. There has to be a short somewhere. Not sure why unless the alternator dying took something with it. I'll let ya know when I find the issue.
