10-27-2017, 06:21 AM | #1 |
Drives: 2016 Chevy Camaro SS Mosaic Black Join Date: Feb 2016
BMR parts not helping.
Just had the cradle bushings along with EVERY available part BMR provides for the 17 Camaro 1LE replaced with a full realignment and I STILL have massive wheel hop.
All the parts were the fully adjustable versions, so not only does it still wheel hop but it now squeaks and rattles which wouldn't have been an issue if the wheel hop was gone. Any suggestions? |
10-27-2017, 06:46 AM | #2 |
Drives: '17 ZL1 Join Date: Jul 2016
Have you spoken with BMR? I think they are known for their helpfulness.
10-27-2017, 08:00 AM | #3 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Id call bmr today and talk with Pete if you can. Its about to be SEMA week so he may or may not be in the office. But someone can help.
Also if you are getting rattles as you said, then something surely isnt tightened and being loose will surely render it less effective. Also what are your alignment specs?
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
10-27-2017, 08:20 AM | #4 |
I'm posting here in hopes that BMR could help.
Using recommended track alignment settings. |
10-27-2017, 08:38 AM | #5 |
what tire setup are you running? have you tried adjusting pressure?
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
10-27-2017, 08:40 AM | #6 |
Drives: 2017 Camaro SS 2SS Join Date: Jun 2017
This may be a stupid question, but do you have directional tires? If you do, Make sure they are rotating the correct direction. I've seen this before on other forums.
10-27-2017, 09:50 AM | #7 |
The tires are the factory O.E.Ms.
And thank you. |
10-27-2017, 09:56 AM | #8 |
Drives: 2016 Camaro 2SS Join Date: Aug 2009
Hey Robby,
Let's start with getting all of the pertinent information on the table and we will start to figure this all out from there. You said the car is a 1LE... V6 or V8? What BMR part numbers do you have on the car? MRC? How old are the tires and what air pressure? Describe the wheel hop: a flutter? violent? how is power being applied? etc. We'll get it all figured. I want you to be happy. This is the first case I've seen where the parts haven't been effective. Thanks, Pete |
10-29-2017, 09:34 AM | #9 |
1LE SS version, MRC, OEM tires 8000 miles, 32 pounds each, all the parts were ordered directly from BMR over the phone so I assume the parts are correct.
And the wheel hop was violent, just like it was before all the parts were installed. If the upper and lower trailing arms were installed incorrectly in other words uppers in the lower position and vice versa, parts look identical, if there was a mix up, could this cause it? |
10-30-2017, 09:44 AM | #10 | |
The upper control arms and lower trailing can possibly be swapped when installed. There is a very small difference in length between the two arms, but normally the alignment is so far off when the arms are swapped that it is pretty noticeable. Either way, I don't think that would have an effect on wheelhop, but it isn't something we've tested. Stupid question before we start chasing stuff... Are the MRC shock sensors all connected and everything plugged in properly? That would certainly cause an issue since the shocks would be super soft. If they are, does the wheelhop change in different driving modes? Thanks, Pete |
11-12-2017, 08:22 PM | #11 |
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport Join Date: Nov 2017
Any updates?
11-13-2017, 08:42 AM | #12 |
11-21-2017, 03:26 PM | #13 |
Kinda of interested also, Robbie did you get it figured out?
11-21-2017, 03:29 PM | #14 |
Thread Tools | |
