11-10-2017, 07:46 PM | #43 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
What about the SS lowering kit (non-MRC): https://www.thatgmpartsguy.com/suspe...su?parent=1034
I'm curious how those spring rates compare to the stock SS and SS 1LE.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
12-03-2017, 06:08 PM | #44 |
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1 Join Date: Jun 2017
Any update on the ZL1 and ZL1 1LE spring rates ?
12-31-2017, 06:38 PM | #45 |
Drives: 2016 2SS Join Date: Dec 2015
F1FTY, do you happen to know the part number (eg 84186925) or code (eg AAV9) for the factory GM springs that you tested? There appear to be at least three distinct spring codes for an MRC-equipped Camaro, and it would be nice if we could link the codes back to an actual spring rate. Generally, there should be a tag on the spring with the code and PN.
01-07-2018, 08:57 AM | #46 |
Drives: 2017 Camaro SS Join Date: Sep 2017
Would really like to know this as well.
Also on the MRC SS, I believe there is no internal bumpstops for the inverted struts, does this mean that the rates would be different in the front? Does anyone know if the shock lengths between the SS MRC vs Non MRC lengths are the same?
Jeff Wong
ESP Camaro Last edited by jwisjw; 01-09-2018 at 03:35 PM. |
01-08-2018, 04:26 PM | #47 | |
You could also inquire with Matt at ThatCamaroPartsGuy as he is who I got my GM kit from.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
01-10-2018, 11:25 AM | #48 |
Fifty, When testing these springs, are the dyno graphs from uncompressed to coil bind? How many inches of travel until coil bind, if so?
Jeff Wong
ESP Camaro |
01-10-2018, 12:04 PM | #49 |
john powell who is making the yyz springs also has similar info but has not released it to the public but has a very interesting findings he told me lol
01-10-2018, 12:10 PM | #50 |
Yeah, I'm very curious because if you assume the front springs were tested from fully uncompressed to when it ramps up, that would mean the corner weights of the car would be engaging the the front springs to the stiffer rate and not so much the "178lbs/inch" rate. So really the average lbs/inch rate is irrelevant and what needs to be focused on is after the 900-950lbs/inch. Unfortunately I don't have rear motion ratio #'s so I can't really conclude anything in my mind.
Jeff Wong
ESP Camaro |
01-10-2018, 04:34 PM | #51 |
Drives: Camaro Justice Join Date: Jun 2007
If measurements are taken in 20mm or 1" increments you get a read on the coil.
01-10-2018, 09:25 PM | #52 |
Yes. Not sure, would have to bring them back to the shop to have them tested.
01-10-2018, 09:28 PM | #53 | |
01-10-2018, 10:47 PM | #54 | |
Corner weights based on research have the front corners at 950+
Jeff Wong
ESP Camaro Last edited by jwisjw; 01-10-2018 at 11:02 PM. |
01-11-2018, 08:36 AM | #55 | |
The shop I used was R/T Tuning in Dulles.
03-17-2018, 11:45 PM | #56 |
Drives: 2016 white 1ss A8 Join Date: Jul 2016
so what is the best spring for a 1ss non mrc that will lower the car safely
Tags |
1le springs rate |
