09-13-2020, 07:15 PM | #15 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Dang, I was gonna recommend the titanium shims. Good luck!
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
09-13-2020, 10:55 PM | #16 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Btw, when i ran APs i still had to rebuild them fairly regularly when paired with DSUNOS. That's why they (Essex) sell rebuild kits and even offer inhouse mail in service. There is no such thing as free lunch (advertising notwithstanding Best of luck and Cheers! |
09-14-2020, 12:48 PM | #17 |
Drives: 2019 Camaro 1SS 1LE, Riverside Blue Join Date: Jul 2019
Thanks, your experience is always greatly appreciated. Just looking for a little extra insurance and also for some reason really liking the extra thickness on the pads (25mm vs say 16mm). With respect to pads - with the purchase of the kit, you get the first set of Ferodo pads at roughly 50% off, I was leaning toward the 1.11 pads but Ken suggested the 3.12 pads and I went with those. Sounds like you'd recommend a lower torque pad - DS2500's maybe?
PDR, CAI intake, Kooks headers & exhaust, AP Racing front big brake kit, DSC Sport RT coil-over kit & suspension controller, G-Force driveshaft, Braile battery, Anderson Composites deck lid, CMS Roll Bar, Schroth ASM Harnesses, BMR rear cradle lock out, ZL1 front lower control arms, SLP rear toe rods, ACS ZL1 Side Skirts, Apex 19x11" wheels.
09-14-2020, 02:01 PM | #18 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I went with the Girodisc rings on my 1LE. I would check them or the DBA discs out if you decide to not go the OEM disc/ring route.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
09-14-2020, 02:20 PM | #19 |
Thanks TJay74, you ever get down to the North Texas tracks? I know crossing the Red River can be intimidating for Norman folks (other than to go to the Cotton Bowl once a year).
09-14-2020, 02:28 PM | #20 | |
When i purchased mine, i only had limited choices. To be clear, mine was a Sprint version, but my car was a sub 3000lb C5Z dedicated track car (aka a trailer queen). 3.12 is the newest and highest torque Ferodo by a mile. Even with DSUNOs (which used to be a dop dog) my seals would go and pistons eventually stick and drag - leading to a rebuild. I too used the 25mil pads, they lasted longer, but not that much. Maybe 2-3 days extra. Overall i liked the kit, but I recall paying thru the nose for pads and replacement discs. That's one of the issues with a proprietary kit: you can no longer hunt for cheap OEM parts at Rockauto etc. To this end: did ya by AP Racing Essex, or a factory kit? More musings on the pads: much depends on what venues one attends. At tracks with mostly high speed sweepers and long straight(s) brakes have sufficient cooling to recover, no matter what heat a pad will generate. But, at "bull ring" style venues with tons of slow/mid speed corners and short straights, the brakes simply may not have sifficient opportunity to recover and cause heat soak. And fry things as a consequence. Heat management is the very top priority for any race/performance brake manufacturer and ditto for any race team. That's a fact, even though their design purpose and expectations are much different than ours (a race vs several track days, or even a full season of lapping). Pad choice plays a dominant role here imo. And even at the highest level of pro racing (like IMSA), teams often run low/mid torque pads. But again, this may depend on the venue, length of a race, driver preference, etc. Another thing to consider is ability to trail brake and use brakes to rotate the car (which is crucial for late braking, fast corner entry rotations and good laptimes). While any pad will permit this, lower torque pads wont stand a car on its nose and hence are easier to carry into a corner and modulate as necessary, while managing weight transfer being easier for a driver. Hope this helps. Many of us like different choices here, just like many pros like different choices too. So there is no one perfect answer here plus many variables. But a rule of thumb is this: if you get fade, lower the pad torque. And always pay attention to brake heat management - regardless. Cheers! |
09-14-2020, 03:44 PM | #21 |
Sorry if I was unclear, yes, I have already purchased the AP Racing kit, even before I made the original post. From what I can gather on future costs, it looks like the pads are roughly comparable to the same type pads that fit the stock calipers (for example, Ferodo's from KNS are actually less expensive - go figure), and given the slightly longer life of the thicker pads, they should save a little $ over time. The AP replacement rotor rings are no doubt more expensive than DBA/Girodisk/stock replacement rings, nearly double. So my working theory is that the savings on the pads will help offset the extra expense of the replacement rings, not completely cancelling it out, but to some extent.
09-14-2020, 04:09 PM | #22 | |
I am very surprised that 25mil pads are "cheaper". Cheaper than what though? OEM stockers/ 2500 from Rockauto/Strano? That would be one hell of a surprise to me! Can ya pls elaborate here as it is an interesting point in your savings calcs. Did ya buy factory AP Racing kit, or an Essex one? When i bought mine, some time later they changed the caliper design and with it a hat offset and i was screwed for new hats. Just an fyi. Things might be different now though. Last point: run the same pads F and R to maintain proper brake bias, that our cars are designed for. Especially if F pads are larger than stock. Do NOT stagger the compounds! Cheers! |
09-14-2020, 04:34 PM | #23 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
I had to bring this over from the funny picture thread. Thanks for posting about the poor results you had with those rotors. Like you said, you took one for the team, this may save someone else from the same results. If I could have all the money I wasted on car parts, my retirement would be in Honolulu Hawaii rather that Trenton NJ.
'18 1SS 1LE Black, PDR
09-14-2020, 04:34 PM | #24 |
I was simply comparing the same Ferodo (sorry, does that not sound like the name of a character from The Hobbit?) compound, say DS1.11, in both the stock caliper size vs the AP 9668 caliper size. Stock caliper size from KNS is $496 vs $470 for the AP.
It is the Essex kit. Thanks again, please keep all recommendations coming.
09-14-2020, 04:43 PM | #25 |
Good stuff Boost Creep, thank you. You'd probably get sick of Honolulu anyway, but not your car(s) : - )
09-14-2020, 05:03 PM | #26 | |
Looking at the map, I'd be bouncing off the walls on Honolulu, would need at least Hawaii.
09-14-2020, 06:02 PM | #27 |
Yep, I think the locals refer to that as Island Fever - the island (normally Oahu) can feel pretty small after a while.
09-14-2020, 07:32 PM | #28 | |
As to the pads, is a stocker pad larger vs your AP? And is this $470 for a 25mil? If so, a great price! I pay just over $200 for stockers, which is just awesome as far as cost to performance ratio. Given i target 20 days per season, consumables can add up in a hurry and saving $ is a priority for me. In this vain, 1.11 has the best longevity of any Ferodo racing pad, yet, it is quite a significant step up torque wise over a stocker, or 2500. It also has a nice flat torque curve, which is easy to manage. But, it should run much, much cooler vs 3.12. So i would suggest you put it on your list as a much more economical, proven, higher torque pad. Ditto 2500 if it fits your new kit, simply to keep heat down and hence conserve the whole brake assembly, hubs and yes: tires. NB I do think Ken is a super nice guy and very accommodating. But i am not at all sure how much first hand experience he has wrt products he sells. So use your own judgement Last edited by TrackClub; 09-14-2020 at 10:27 PM. |
