Old 11-24-2018, 08:46 AM   #1
JD_
JD_'s Avatar
Drives: 2018 2SS 1LE in Nightfall Gray
1 Original rear tire replaced... Should I replace the other as well?
At VIR in October I had a rear tire get cut and subsequently patched. Since then Chevy replaced the tire under the wheel and tire protection plan, leaving me with one new rear tire while the rest of the tires have 6 track sessions of about 20 minutes each and less than 3,000 miles total.
So now I am wondering if I need or should replace the other rear tire. I think the fronts will be just fine.
Any thoughts?
thanks,
JD
JD_ is offline   Reply With Quote
Old 11-24-2018, 11:20 AM   #2
srcstc
They didn't give you a hard time getting it replaced even though you patched it?
srcstc is offline   Reply With Quote
Old 11-24-2018, 12:54 PM   #3
JD_
JD_'s Avatar
None at all.
Old 11-24-2018, 01:30 PM   #4
BigShow1960
BigShow
BigShow1960's Avatar
Drives: 2017 1 Camaro + Chevy Avalanche
I bent my right front rim and damaged the tire at the track last weekend. When the new rim and tire come in I'm planning on having the new tire shaved to match the old.
BigShow1960 is offline   Reply With Quote
Old 11-24-2018, 05:07 PM   #5
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
What wheel and tire protection plan? After sale purchase?
Uncle Sam is offline   Reply With Quote
Old 11-25-2018, 05:57 AM   #6
JD_
JD_'s Avatar
It was the protection plan offered at the time of sale thru koons Chevrolet
Old 11-25-2018, 08:11 AM   #7
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
Interesting. To th OP probably OK �� I bought the auto nation cover everything warranty and had a rear repair at 400 miles. Wonder if I should press for a new tire. I'll have to dig out paper work.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
