Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 03-25-2018, 09:43 AM   #1
GMteSSted
GMteSSted's Avatar
Drives: 2018 ZL1 1LE
Recommend new Clutch, LS-9?
I need to replace the clutch in my Z/28, the original made it 11k miles and 15+ track days.
I'm looking for a replacement with a lighter flywheel and no chatter.
Thinking about going with the OEM LS-9, any comments or suggestions?
Anyone have experience with a different replacement that meets the two criteria? I'm not really wanting to break the bank on a high dollar racing clutch.
Any slave cylinder recommendations are appreciated too.
Thanks!
GMteSSted is offline   Reply With Quote
Old 03-25-2018, 10:43 AM   #2
Dutchman427
Dutchman427's Avatar
Drives: 2012 ZL1 #1329 M6
Give Steve @ Monster Clutch a call.
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports
784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128
Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms
http://www.camaro5.com/forums/showthread.php?t=395950
Rapid Motorsports 396ci Build
https://www.camaro5.com/forums/showt...1#post10321301
10.832 @ 130.99
Dutchman427 is offline   Reply With Quote
Old 03-26-2018, 07:24 AM   #3
ronchev
ronchev's Avatar
Drives: 14' Red Z/28 #336
From what I have found the LS9 is heavier but stronger.
I wanted lighter too but not small race type clutch so after much looking around and reading I just installed a stage 2 Diamond clutch kit with there billet steel flywheel, its 15 pounds lighter than the LS7 clutch combo and higher load rating than stock. I have not tried it yet as Ive not finished engine mods Im working on.
ronchev is offline   Reply With Quote
Old 03-26-2018, 08:09 AM   #4
xc_SS/RS
Drives: 2010 Camaro SS/RS
you could go back to stock but with a fidanza lightweight flywheel. not sure which flywheel you would need though. Monster is also a good choice. if you have the coin you could look at RPS carbon clutches.
if you do a search on ls1tech for lightweight clutch options you will get much better search results
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 03-26-2018, 08:37 AM   #5
frenchsquared
frenchsquared's Avatar
Drives: 15 Z28, 01 Corvette, 96 Corvette
11k miles and 15 track days? Seems GM should be replacing that clutch. Im at 8k miles and over 20 track days. I notice it slipping more and more when pulling in and out of the garage, but never thought it might be getting bad. This clutch has slipped going in and out of the garage since they day the car was built. Wonder if GM will replace mine.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
frenchsquared is offline   Reply With Quote
Old 03-26-2018, 12:56 PM   #6
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
+1
Nick S is offline   Reply With Quote
Old 03-26-2018, 03:16 PM   #7
ronchev
ronchev's Avatar
I tried to get mine covered under bumper to bumper last year for a noise when you push the peddle down witch I believed was something in the pressure plate auto adjustment mechanism that the stock cover has with no luck, and I'm an ex Chevrolet tech that still knows people in the field. Dumb luck I'm not sure but I spent a lot of time trying to figure if I wanted to get the stock LS7 clutch (great price) or upgrade and try to cut a few pounds off the heavy Stock set up.
As a side not I know this is not the place but I do have a new Fidanza aluminum LS7 flywheel that I did not use that never been out of the box. I will post it in correct place for sale at some point.
Old 03-27-2018, 07:49 AM   #8
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
LS9 clutch is twin disc and should "bolt right up." Probably a reasonable cost/performance option...
Schlok is offline   Reply With Quote
Old 03-27-2018, 08:56 AM   #9
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Hi, no it's not a drop in, the fly wheels are not the same, you need a new one that made for our 6 bolt cranks, and mates to the ls9 clutch, then you need a spacer for the trow out bearing. They sale a kit for this upgrade.
2SSRS@Gen5diy is offline   Reply With Quote
Old 03-27-2018, 09:04 AM   #10
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Thanks!
Stock power?
Road course use?
JusticePete is offline   Reply With Quote
Old 03-27-2018, 11:03 AM   #11
pat_t
Drives: .
Originally Posted by ronchev View Post
I tried to get mine covered under bumper to bumper last year for a noise when you push the peddle down witch I believed was something in the pressure plate auto adjustment mechanism that the stock cover has...
I had a problem at just 1000 miles with the adjustment mechanism being set wrong. A new cover and friction plate sorted it.
I have the original cover/pressure plate in my garage - at some point I want to see if the adjustment mechanism can be correctly reset.
If I went aftermarket I would go multiplate - maybe the Quartermaster setup Russ has on the Fusion of Ideas car or Tilton full carbon. Good mass and intertia savings to be had that way. Makes the engine more revvy and responsive.
pat_t is offline   Reply With Quote
Old 03-27-2018, 03:34 PM   #12
GMteSSted
GMteSSted's Avatar
Originally Posted by JusticePete View Post
Stock power?
Road course use?
Stock power, yes for now, may up the cam later.
Road Course mostly, some street.
Pete , you may remember driving my Z/28 on the autocross at Camarofest this past year.
Old 03-27-2018, 03:38 PM   #13
GMteSSted
GMteSSted's Avatar
I've talked with Steve at Monster, nice guy. I'm concerned about some of the monsters users who have complained about squealing and chatter.
Not familiar with fidanza, will check them out.
Old 03-27-2018, 03:39 PM   #14
GMteSSted
GMteSSted's Avatar
Been looking at the Mantic clutch kit too, anyone have experience with this brand?
clutch or transmission, clutch replacement, ls-9, slave cylinder, z/28
