08-04-2014, 10:02 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
How to loosen up Lug nuts Easily
I had my new wheels put on by my local tire shop and love them but its come time for me to put new pads and rotors on. The shop must have torqued them down a little to much cause my socket wrench can't seem to get them off. Is there some kind of adapter i can get for my wall plugged drill to get these bad boys off?
08-04-2014, 10:09 PM | #2 |
Check if they used a torque wrench or torque gun. Just keep trying with the socket wrench or get one with more leverage
08-04-2014, 10:10 PM | #3 |
Get a piece off pipe big enough that would fit the wrench into that pipe
Give it a good push , and you should be good to go . |
08-04-2014, 10:15 PM | #4 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
Use the pipe as mentioned above to get more leverage if not you could always try pushing on the wrench with your legs instead.
08-04-2014, 10:20 PM | #5 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
They should've used a torque stick. Use a breaker bar and a piece of pipe
2011 2SS/RS built 8/24/10
08-04-2014, 10:39 PM | #6 |
08-04-2014, 10:41 PM | #7 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Correct. My manual shows 110lbs....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
08-04-2014, 10:42 PM | #8 | |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
If you plan to put them back on, definitely use a torque wrench to the exact setting explained in the owner's manual. |
08-04-2014, 10:49 PM | #9 |
Drives: 2013 2LT/RS Silver Ice Metallic. Join Date: Dec 2013
08-04-2014, 11:05 PM | #10 |
Im Trying all of these. I even went to home depot and got an attachment for my corded drill but that wouldn't even budge them. I don't want to slip and scratch my wheels. This would be a lot easier if they weren't semi con-caved. Ive got the Style 41 wheels with the gorilla locking lugs. Trying not to strip them and don't want to slip off. I might just have to go back there and tell them to loosen them up a bit for me.
08-04-2014, 11:13 PM | #11 |
08-04-2014, 11:16 PM | #12 |
Remember, lefty lucy, righty tighty!
08-04-2014, 11:18 PM | #13 |
Drives: 2011 Summit White 2LS Join Date: Jun 2011
What tool are you using? I've got a lug wrench with a built in long handle that gives you some great leverage. What part of SoCal are you in? If you are anywhere near Pasadena you are welcome to use it.
08-04-2014, 11:28 PM | #14 |
I tried all of the cheater bars and everything else in my tool box with the help of my girl. NO luck. I swear the cheater bar wanted to break before these came off. Ill be driving up there this thursday on my day off to get these loosened and give them a piece of my mind..
