08-16-2013, 10:51 AM | #1 |
Drives: camaro v6 Join Date: Aug 2013
Speaker Question/Warranty
Lately I've been turning the volume on the radio all the way up and playing a song with the best bass I can fine. Normally I keep the radio very low but a neighbor has been acting out lately so I've decided to be annoying as well. My question is what are the chances of the speakers blowing? This would be covered under the bumper to bumper warranty correct?
08-16-2013, 12:49 PM | #2 |
Drives: camaro Join Date: May 2013
There is a very good chance you will blow it. Yes...covered by bumper to bumper.
Hyperblue/JetBlack |
08-16-2013, 02:34 PM | #3 |
Drives: 2SS/RS Join Date: Sep 2008
08-16-2013, 02:47 PM | #4 |
Austin LT
Drives: 1LT - Airaid,JBA Axleback,VMax PTB Join Date: Jun 2009
How is turning up your stereo to the max considered "abuse"....the speakers should be rated for whatever the system can push through them.
08-16-2013, 02:57 PM | #5 |
08-16-2013, 03:32 PM | #6 |
Drives: 2010 IOM 2SS/RS Join Date: Feb 2012
I blew my left front lower speaker (driver door)...never had volume above 35, most of the time its at 22 to 30. It happened after my warranty had expired and I was even contemplating getting the extended warranty. So now it pops at anything with a lot of bass and the volume above like 23. So I have to turn the bass all the way down to like -3 on the EQ to be able to get more volume.
Just thought I would share, as you can see it is very possible to blow the damn speaker even under normal conditions.
08-16-2013, 04:13 PM | #7 |
can anyone please clarify this issue?
08-16-2013, 04:23 PM | #8 | |
Shenanigans
To answer your question, no it would not be covered under a factory bumper to bumper warranty if you state you had the music cranked. That would be classified as "Negligence." Now, if you stated you had it up at 18-20, not max, and it blew...then that might be a different story.
2010 CGM 2SS/RS L99 |
08-16-2013, 05:16 PM | #9 | |
Austin LT
08-16-2013, 05:20 PM | #10 |
Retired from Car mfrs....
Correct answer.....at least with the car mfrs I worked with, handling warranty issues....
08-16-2013, 05:29 PM | #11 | |
Drives: 2012 LS M6, Black Join Date: May 2009
That's pretty basic stereo knowledge. Never turn one up all the way, and turn it down if you hear distortion that's not meant to be there. John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
08-16-2013, 05:56 PM | #12 | |
Mine never goes above 14 because above that is just too loud for everyday use, most of the time it's at 12 or 13. The db's that is put out at 20+ doesn't fall under normal use. No wonder your speaker blew. Just because something "can" do something, doesn't mean that it can maintain it and do it often enough, it will break. You car can run at 6.5k rpms but if you drive it like that too much eventually you will need a new engine. It's the same thing with speakers. |
08-16-2013, 06:30 PM | #13 |
Can anyone provide a reputable source to back up their claims?
08-16-2013, 06:32 PM | #14 |
Austin LT
I understand and am not disputing that on most stereos there is inherent distortion at the top of the range that can cause speaker problems. My issue is saying that the bumper to bumper warranty won't cover a "blown" speaker unless I lie about it. That and the fact that some people answer questions as if they are experts about a particular subject and not just giving an opinion. If I am on the wrong side of this, well, it's just my turn to be an a$$h0l3.
