Old 08-08-2019, 02:24 PM   #1
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Fuel pump choices(ZL1+DSX)
Well it looks like DeatschWerks discontinued the 400lph drop in fuel pump module for our cars. So i am thinking i will just install the ZL1 pump for now. I still have my BAP but there is a sale pending on it and i am thinking its just a bandaid that will only support 600-650 rwhp. I'm lowering my goal to 500-575 rwhp with the single turbo kit anyways. I do plan on getting the DSX aux fuel pump when i switch over to bigger injectors and E85 down the road. I have 850cc Fast injectors. So my question is for you boosted guys will the ZL1 pump alone be ok for my power goals with 91 octane?
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 08-08-2019, 02:44 PM   #2
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
if you are just running 91 at 575, you will be fine with the zl1 pump.
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
gm2376 is offline   Reply With Quote
Old 08-08-2019, 03:16 PM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I hit 640 with a ZL1 pump and a BAP with plenty to spare.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 08-08-2019, 03:26 PM   #4
IKILLEDSUPERMAN_ZL1
I'm not gonna run the BAP and this is thru an auto too. I figured the L99 soaks up at least 50 more hp then the M6?
Old 08-08-2019, 06:13 PM   #5
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
Do you know when and why? I did a search and didn't see anything
redirish is offline   Reply With Quote
Old 08-11-2019, 06:27 PM   #6
RockSVT
Drives: 2010 Camaro SS
The 6l80 is pretty efficient, I doubt your gonna lose 50hp compared to manual. I have a similar setup Cam, LSA, ZL1 pump & FPCM (no bap) made 630 (100 degree day way heat soaked) on 10lbs with no fuel pressure problems. I know the Fuel System is something it's better to overshoot than undershoot but the ZL1 pump and fpcm is better than it gets credit for imo
Good luck with your build!
RockSVT is offline   Reply With Quote
Old 08-12-2019, 07:37 AM   #7
Benman
Benman's Avatar
Drives: 13 IOM 2ss RS manual
I was told by a very reputable turbo outfitter that a stock LS3 SS fuel pump with a BAP will support about 620 WHP, and the ZL1 would carry it to 680-700, both of these are on pump gas. For any more HP or using E85 I will need to go to a double or triple pump setup. I don't know, does the L99 use the same fuel pump as the LS3?
Rectangular Dollars will beat Cubic Inches
Benman is offline   Reply With Quote
Old 08-13-2019, 10:35 AM   #8
Slickcas
Drives: 12' 2SS/RS LS3 IBM
I am running a ZL1 pump with the FPCM set to 65 psi. and DSX aux pump set to turn on at 4 psi.
Also have ID1050X injectors. With the TH400 I am at 625 on 93 and 680 on E85. No pressure drop at all. Injector cycle was like 70%.
I am running a centrifugal supercharger.
Slickcas is offline   Reply With Quote
Old 08-13-2019, 10:42 AM   #9
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
I went a little bit different route. I know you wanted info on a BAP
In my case I am running a Fore Innovations Triple pump setup staged on E85
I am also on a centrifugal supercharger as well. As I have not dynoed it as of yet, I am trying to reach around 650rwhp as this is my daily as well as it is SBE and everything else is stock. The main reason I ended up doing it this way was because if later down the road (which I will) I wanted to get more power the last thing I would need to check is the fuel as I have enough pumps and the lines are big enough to hold the fuel and the pressure I would need to run either 93 tune or E85 tune.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 08-13-2019, 04:09 PM   #10
Scott S
Scott S
Drives: 2011 Camaro 2SS
My setup
I am running stock pump with SMG auxiliary with FIC 1000 and E85 with an LSA supercharger with a 2.50 pulley putting 709 RWHP. Going to upgrade pump this winter to the ZL1 and a couple other small changes but should be at 800 tire then. Being told that is getting close to Maxing out the fuel system but it will work.
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
Scott S is offline   Reply With Quote
Old 08-14-2019, 11:22 PM   #11
UNRIVALED SS
UNRIVALED SS's Avatar
Send a message via Yahoo to UNRIVALED SS
I can tell you the bone stock pump will make 575 through the 6l80e . That is the all out limit. Anymore and you’ll drop fuel pressure and have to be creative to make it work. The ZL1 pump will be good for well over 600.
UNRIVALED SS is offline   Reply With Quote
Old 08-15-2019, 02:58 PM   #12
eLeSthree
Drives: 2011 Camaro SS 6sp
Exactly. My friend has a P1sc on his 2015 SS m6 and makes 751/675. He runs only E85 (e80ish) and only has a ZL1 pump, KB BAP, and tuned FPCM.
His computer is commanding 58psi, and his FP tapers off to 43psi. He has ID1300x2 injectors that see around 70% dc.
If we weren't data logging, we wouldn't know that his fuel pump is overworked. I suggested that he should get a better fuel system. If anything happens, clogged fuel filter, or BAP fails, he would never know... especially since he has no Wideband.
Coincidentally, he just recently popped a piston. went 418.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
