Old 04-18-2018, 07:50 AM   #1
Gotit4cheap16
Drives: Victory Red
Dsx aux fuel pump Kit fuel pressure
So I have the dsx kit installed and tuned for E85. Yesterday while roll racing a friend, I still see my fuel pressure at the rails through my aeroforce gauge drop down to 43psi at wot. Why would this be?
Gotit4cheap16 is offline   Reply With Quote
Old 04-18-2018, 07:58 AM   #2
DSX Tuning
Drives: 2019 Corvette ZR1
Use something other than the Aeroforce to check pressure. I've seen many instances of the Aeroforce reporting pressure incorrectly when it's high.
DSX Tuning is offline   Reply With Quote
Old 04-18-2018, 09:47 AM   #3
Gotit4cheap16
Drives: Victory Red
OK thank you. Would a manual fuel pressure gauge work?
Old 04-18-2018, 02:34 PM   #4
ecreps
Drives: 2014 1LE, 1996 z28
If you have HP tuners it should be logged there.
ecreps is offline   Reply With Quote
Old 04-19-2018, 12:03 AM   #5
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Are you using the stock SS FPCM tune? If so it’s doing exactly what it’s told and dropping pressure higher rpm’s.
Slickcas is offline   Reply With Quote
Old 07-23-2020, 08:32 AM   #6
SLY5ACE
Drives: 2013 camaro ss 1le supercharged
I AM HAVING THE SAME ISSUE I HAVE THE DSX FUEL KIT ITS TUNED FOR 93 OCTANE AND 385 AND ON THROTTLE ABOUT MID RPMS IT DROPS FUEL PRESSURE AND CREATES A MISFIRE
SLY5ACE is offline   Reply With Quote
Old 07-24-2020, 08:22 AM   #7
chadbeau
Drives: white zl1
double check the connection at the map sensor! it wasnt a good enough connection on mine and when i would wiggle it and watch it on hp tuners it would jump all over the place without the car even running! i gently bent the pins inside the connector and plugged it back in and never had another problem!!
chadbeau is offline   Reply With Quote
Old 07-24-2020, 11:12 AM   #8
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
If you have the ability to log data, that will tell you what is going on. You can watch fuel pressure in real time, as well as MAP data to see if you are getting erratic data there. I'm inclined to agree with the others that your most likely culprit is an improperly tuned/adjusted FPCM.
Let us know what you find.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 07-25-2020, 01:52 AM   #9
madmikeismad
Drives: 2012 ZL1
Also, if you're a zl1, make sure to put it on the rear sensor on the lid. Otherwise jump the pump manually and make sure it works at all. I've found that unless you're moving a ton of air, the pump will move enough fuel that the fpcm can't slow down the in tank pump enough to drop pressure to requested, so if you're dropping to 40's and requested is anything higher, then the aux pump probably isn't turning on. Sorry if this doesn't make sense, it's late and I got an early start today.
'12 ZL1 - RPM 5", TSP 2" headers, Speed Engineering 3" header back, Dayco 8.66 lower/LPE 2.38 upper with solid isolator and 10 bolt hub, hand ported blower and snout and went way too far, ID1050x's, DSX aux harness with a summit 400lph pump on E, NGK TR8's with Taylor wires, 160* tstat, NW 102, UPR catch cans, HP Tuners, Stock unopened long block
madmikeismad is offline   Reply With Quote
Old 07-25-2020, 05:22 AM   #10
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Aeroforce reads what the computer reads.
Bo White is offline   Reply With Quote
Old 07-27-2020, 12:14 AM   #11
Slickcas
Sounds like you need to tune the FPCM. Think I had my setup set to 450KPA (65psi) all the time. Stock SS is 58 And set to drop pressure as the RPMs go up. Do not know why GM did it.
