07-30-2015, 05:00 AM | #1 |
Drives: 2013 Lt 2 Join Date: Apr 2015
Sea Foam
Is it ok to put Sea Foam in the gas tank of 2013 Camaro Lt 2?
07-30-2015, 05:18 AM | #2 |
Drives: 2016 camaro 1SS Join Date: Jun 2013
Why would you want to do that? Your cars still new shouldn't need to add sea foam unless you're having issues with the car. If it ain't broke don't fix it.
2016 BLK Camaro 1SS/LT1 M6: NPP | black front/rear bowtie | Blacked out taillights 2011 IOM Camaro 1SS/RS LS3: Stainless works 1 7/8" LT headers w/ Offroad pipes | TSP Cam 235/239 on a 112 | Powerbound 25% UD Pulley Roto-Fab Cold Air Intake | SW Retro Chambered Catback Exhaust | VMax Ported TB | Hurst Short Throw Shifter Trunnion upgrade | LSA Oil Pump | BMR 1.25 Spings | R1 Concept d/s Rotors Tuned by Lashway Motorsports - 501 Hp 430 ft-lb |
07-30-2015, 05:24 AM | #3 |
having FUN now 13.66@101
Sea foam rally won't help much in the gas tank as no fuel passes thru the intake manifold and over the valves, which is what mostly you need to have cleaned. You can spray the sea foam directly into the intake manifold. There are a couple good threads in this forum that cover this subject. The best thing to get for your direct injected engine is a catch can.
07-30-2015, 05:35 AM | #4 |
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS Join Date: Jun 2015
Spray it into the manifold
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold 2001 Camaro SS SOM M6- sold 1999 Firebird Formula A4- sold |
07-30-2015, 08:50 AM | #5 |
Lurking in my SS
Drives: '14 2SS/RS L99 Join Date: Jul 2014
07-30-2015, 09:27 AM | #6 | |
Drives: 2015 LFX Auto Join Date: Apr 2015
07-30-2015, 03:50 PM | #7 | |
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
07-30-2015, 04:01 PM | #8 |
I'm with you. Now for a PI engine like the LS3 and L99, a solvent based upper induction cleaner can be used with little chance of damage to the engine as there is only a limited amount of soft carbon built up on the pistons and nothing generally on the valves.
07-30-2015, 07:28 PM | #9 |
Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
Seafoam is garbage
07-30-2015, 07:49 PM | #10 |
Institutionally Insane
Care to explain based on experience? Or is your comment baseless? If you use top tier fuel, and change your fuel filter as recommended, there is no need for Seafoam for the oil, fuel or upper valvetrain (valves) If you do a lot of stop and go driving, neglect oil changes, buy crappy gas, don't change fuel filter, don't change air filter, Seafoam will help. Broad-stroked, a 2013 vehicle, used regularly, properly maintained, needs NO additives. I use Seafoam in all my older vehicles (94 ZR2 and 03 Cavalier), 2 cycle equipment, tractor..I have been using it for 15-16 years. Stuff works great. Pay no attention to the inflammatory idiot who posted prior.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
07-31-2015, 06:41 AM | #11 |
I Seafoam about 2 tanks before oil change. Car has almost 47K miles and is running fine. I also run an Elite Catch Can.
07-31-2015, 07:57 AM | #12 |
Lurking in my SS
I wasn't impressed either. Glad I didn't try it. That guy tries to debunk a lot of stuff. He has debunked most of those off the shelf additives, boosters, and what have you. Its a honda lol but it's something to go off of. If it does nothing for his honda it won't do anything for us.
07-31-2015, 08:08 AM | #13 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I'd be more interested to see what it does on the valves. Carbon on pistons does not really affect performance. I suppose enough of it could create a hot spot.
I'd personally rather run a can of Seafoam or other upper intake cleaner every once in while than have a catch can just because I don't like crap hanging off my engine.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
07-31-2015, 10:04 AM | #14 | |
