02-18-2018, 07:41 AM | #1 |
Drives: 2013 Camaro SS Join Date: Sep 2017
Popping Metal noise on the rear
Quick question guys. Whenever I go over a deep bump, my car makes a noise on the bottom rear side. Sounds like a metal popping. No mods except for an MBRP axle back and a tune. Also, I Just started noticing it the other day. Had the axle back checked but everything is still tight and intact. There were a few scrapes tho.
02-18-2018, 10:03 AM | #2 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
Have you checked all the rear suspension?
Sent from my SM-G955U using Tapatalk
Bone Stock |
02-18-2018, 10:07 AM | #3 |
Drives: 2010 Camaro SS 2SS Join Date: Jul 2017
How many miles? It could be a drive shaft CVD - when you go over a large bump it move your suspension a large amount. This in turn changes the angle of your drive shaft, if it is worn out or damaged it could be binding and popping.
who knows though... |
02-18-2018, 11:05 AM | #4 | |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
02-18-2018, 02:33 PM | #5 |
02-18-2018, 02:35 PM | #6 |
Car has less than 12k miles.
02-18-2018, 02:40 PM | #7 |
02-19-2018, 11:06 AM | #8 | |
Originally Posted by J1o6sh
Quick question guys. Whenever I go over a deep bump, my car makes a noise on the bottom rear side. Sounds like a metal popping. No mods except for an MBRP axle back and a tune. Also, I Just started noticing it the other day. Had the axle back checked but everything is still tight and intact. There were a few scrapes tho Quote:
Well the obvious solution would be is to slow down going over speed bumps and through pot holes.
02-19-2018, 11:26 AM | #9 |
Drives: 69 SS Camaro 2019 Corvette GS Vert. Join Date: Jan 2017
Have your rear suspension knuckles checked. One of the bushings in the left rear knuckle was worn bad one my wife's 15 2SS and was clunking when I applied any, and I mean any torque. The car had 30,000 miles when I noticed it.
There is a fine line between hobby and obsession and I think I crossed it!!
02-19-2018, 01:22 PM | #10 |
Thanks. Yes it’s on the drivers rear side. You’re right, you can also hear the noise when any torque is applied.
02-19-2018, 10:34 PM | #11 |
Just got my car back and you were right. They told me the bushing was loose on the driver side. fortunately, it wasn’t worn out yet.
02-20-2018, 07:25 AM | #12 |
Good deal!! Glad you caught it early.
03-20-2018, 09:22 PM | #13 |
Alright guys the noise came back. Does this have anything to do with me tuning the car?
03-21-2018, 01:17 AM | #14 | ||
Drives: Miss Con Ception Join Date: Aug 2016
When they said it "wasn't worn out" did they mean it was worn, but not enough to require a replacement? And, being worn as a result of being loose (or the other way around) would indicate to me a replacement. Ask them "how is the right side?" and if they say, "well, it's okay for now..." have them replace that as well. Be sure they replace the bolts and nuts and inspect the attachment points while it's apart. Better to catch these issues early then wait until there is a failure.
2011 1SS/RS LS3 CGM
