Old 12-23-2015, 02:40 PM   #1
Balue
Balue's Avatar
Drives: 2013 SW 2SS/1LE
1LE is now cammed and heads ported!
Just picked her up from CMS, went with stage2 cam and ported heads. She put down 478rwhp/427rwtq. Wanted a nice conservative road race build. Car drives like stock and pulls hard. Don't know how hard yet as it was damp and drizzly when I picked her up.
https://youtu.be/bASHLoV_R2k
Balue is offline   Reply With Quote
Old 12-23-2015, 03:28 PM   #2
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Yeah!! nice! I like your wickerbill!!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 12-23-2015, 05:21 PM   #3
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Sweeeet!
cornerspeed92 is offline   Reply With Quote
Old 12-23-2015, 05:25 PM   #4
Scotty D2014
Drives: 2014 SS1-1le Crystal red metallic
That's with ported heads ???
Scotty D2014 is offline   Reply With Quote
Old 12-23-2015, 05:39 PM   #5
toehead93
Drives: 2014 2SS/1LE
Cam specs and dyno graph? Curious to see power curve.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 12-23-2015, 06:19 PM   #6
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
Congrats bro! I like the chop. Are those ported stock heads?
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 12-23-2015, 07:05 PM   #7
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
+1
Just curious, what's your idle rpm set at?
Asking because with my new cam, even though its a boot cam, i'm at 850 ish.
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI
Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018.
Splat is offline   Reply With Quote
Old 12-23-2015, 07:21 PM   #8
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
Sounds about right, doesnt sound like a really aggressive cam + guessing stock ported heads.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 12-23-2015, 07:33 PM   #9
Scotty D2014
Wow ok !! Guys up in Mass are doing that without ported heads .
Old 12-23-2015, 07:39 PM   #10
Ajdin@A2BMotorsport
There are cams that can do this power without heads, it depends what the car is intended for. Lots of factors in dyno numbers as well (dynos, elevations, temp, humidity etc...) if the OP is happy thats all that matters in the end,
Old 12-23-2015, 07:56 PM   #11
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
OP said he is doing a road race cam. They aren't for peak power, since lots of lift is hard on the motor for 20-30minutes at time near max RPM.
They are built for more power under the curve so peak HP will be down but overall useable power is the same or more in some cases.
BigBlock69RS is offline   Reply With Quote
Old 12-23-2015, 08:01 PM   #12
Scotty D2014
Ok I see .
Old 12-23-2015, 08:21 PM   #13
Mark T
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav
Love that sound.
Makes me want to jump in my 1le and go cruising. Now.
But then again, 28 degrees and 3 feet of snow really bring me down to earth.
Mark T is offline   Reply With Quote
Old 12-23-2015, 08:49 PM   #14
Balue
Balue's Avatar
Yes guys thanks for the back up. This is a mild road race cam cant remember full specs but 61x's 114+2 cant remember the duration but it is a custom stage2 road race cam. I also asked for a conservative tune so I can spin at 6k all day! Another reason I wanted smooth flow. Cam only they been getting 440-450 so 478 I am happy with. It has a level tq curve right in the sweet spot for digging out of the corners.
The car feels great drives like stock from down low, again needed in road racing and as in the video you can tell its not wild as the lope is there but not chopping like say a polluter or night fury. Way less lift and separation than those cams that are making near 500 not what i need or was going for.
The heads are stock, cnc ported by WCCH
the build is right where I need it.
Idle is around 850 here is the graph
