TireRack
Old 07-30-2015, 06:34 PM   #1
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Best exhaust sealant and/or clamps?
Are there any good sealants, seals, or clamps that are better than just a stock or simple clamp?
Talking band clamps for butt connections mostly.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 08-04-2015, 08:39 AM   #2
Stainless Works
Stainless Works's Avatar
Drives: Fast
The Stock Clamps are good Clamps But,
We offer a 3" long band clamp that is used in butt connections.
Clink the like below and it will bring you to our website where you can find the options for these style clamps
http://stainlessworks.net/3-high-tor...accuseal-clamp
Stainless Works is offline   Reply With Quote
Old 08-04-2015, 01:23 PM   #3
OmniCamaro
US Veteran
OmniCamaro's Avatar
I appreciate the response SW. Just an FYI: in the description it states they're for ID/OD connections.
Old 08-04-2015, 01:47 PM   #4
Stainless Works
Drives: Fast
See the Picture below. They are made to be both a Butt connection or ID/OD connections. See picture below. They are not pre-formed for ID/OD connection so you can use them as a Butt Connection.
Old 08-04-2015, 04:06 PM   #5
IMJ
IMJ's Avatar
Drives: 2012 SS LS3 | Silver Frost Metallic
PM sent about these for me as well.
Anyone have any input on some kind of sealant pipe liner or epoxy or something like that as well?
Ironman John
IMJ is offline   Reply With Quote
Old 08-04-2015, 08:16 PM   #6
OmniCamaro
US Veteran
OmniCamaro's Avatar
10-4
Old 08-05-2015, 08:17 PM   #7
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Permatex makes a pipe/muffler sealant. I used it on the stock clamps headers to catback to eliminate the little weeping I had there. Used to smell it in the cabin at idle a bit, no more.
http://www.permatex.com/products-2/p...-sealer-detail
Another 1 of 371 '12 T3 LS3 M6's built.
Iam Broke is offline   Reply With Quote
Old 08-06-2015, 11:45 AM   #8
JWoj3540
JWoj3540's Avatar
Drives: 2012 2SS/RS M6
I've used high-temp RTV on exhaust connections with success.
JWoj3540 is offline   Reply With Quote
Old 08-06-2015, 12:36 PM   #9
Stainless Works
Drives: Fast
Any High temp silicone/sealant will work. Put some on the male end and slide him in and clamp it tight and you should be all good.
Thanks
Old 08-06-2015, 08:11 PM   #10
OmniCamaro
US Veteran
OmniCamaro's Avatar
Thanks guys!
Old 08-08-2015, 10:21 AM   #11
IMJ
IMJ's Avatar
Thanks for this info.... I'll check this out!
Ironman John
