Vararam
Old 07-08-2014, 03:52 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
928 RWHP Stock Short Block F1A Camaro by LG Motorsports
Figure I would lead in with just a simple dyno graph.
Since the last car that posted over 900 rwhp...did STD numbers, to be fair I am posting the same correction
  • LG Super Pro Long Tubes and exhaust
  • LG G6X3 cam kit
  • LG ported LS3 heads (11.4:1 compression)
  • FAST 102 intake
  • NW 102 TB
  • ATI balancer
  • Procharger F1A supercharger kit (shows 12 psi at 6900 rpm)
  • Procharger race intercooler
  • Procharger 12 rib drive
  • Procharger race by-pass valve
  • LPE dual fuel pump kit
  • ID 850 injectors
  • Alky controls Meth kit
  • MGW shifter
  • LG Motorsports solid engine and trans mounts
  • Centerforce DYAD clutch
  • DSS shaft and axles
  • Weld RTS wheels
  • 93 pump gas (846 rwhp)
  • 104 octane (928 rwhp)
Car has had a few combo's over the past few years and was not 100% intended to be F.I. when the heads/cam was done to the car, but as you can see the results worked out nicely.
This would not be the build for everyone, but it does give you a very good look into what can be done if you pick your parts wisely and have a solid tune with the LS3.
Small build thread here: http://www.camaro5.com/forums/showthread.php?t=324961
More than happy to answer any questions you might have about the build.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 07-08-2014, 04:01 PM   #2
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
That's awesome numbers. I'm worried about my bottom end at 640 to the rear. Pretty incredible motors for what they are
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
bcguy is offline   Reply With Quote
Old 07-08-2014, 04:35 PM   #3
jr2014ss
Drives: 2014 SS l99
Pm kit installed for a 2014 l99
jr2014ss is offline   Reply With Quote
Old 07-08-2014, 05:50 PM   #4
62nalide
62nalide's Avatar
Drives: 2013 SS
Is that Mr Torque?
62nalide is offline   Reply With Quote
Old 07-08-2014, 07:38 PM   #5
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
There is a video of this car vs a red gt500... That video claims 650whp. What's been changed to pick up this much?
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 07-09-2014, 06:09 AM   #6
H-E
Drives: 2010 zr1 Camaro 2011 vert
Great results! CR is what's king
H-E is offline   Reply With Quote
Old 07-09-2014, 08:27 AM   #7
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Nice
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
Trob85 is offline   Reply With Quote
Old 07-09-2014, 09:38 AM   #8
There is another that claims 10,000 hp too
Old 07-09-2014, 09:39 AM   #9
blake2010ss
Lol.. So this is what he actually makes in video?? Makes more sense with the trashing he gave that Shelby.
1093/1066
Old 07-09-2014, 03:18 PM   #10
mcdoogle6969
mcdoogle6969's Avatar
Drives: 2010 Camaro SS, 2008 Heritage 300C
Did you have any belt slip issues? I'm running a F1A also along with the upgraded intercooler and race bov. it started to have belt slip at 6000rpm at 15.5lbs of boost and just peaked over 900rwhp. I want to go further (as in I want to reach redline with no belt slip issues) but may need to jump to a cog (will probably eat the crap out of belts) or a 12 rib setup. Thoughts?
mcdoogle6969 is offline   Reply With Quote
Old 07-09-2014, 04:05 PM   #11
Depends on the date of the video as to what fuel it was on....I believe in that it was on pump fuel so the 800 tune.
Old 07-09-2014, 04:05 PM   #12
We had a 4.5" blower pulley on the car and ran a 12 rib setup from the get go to fight any issues with slip.....if it did slip, it was not much.
Old 07-13-2014, 01:34 PM   #13
Andy-AMSOIL
Andy-AMSOIL's Avatar
Drives: bicycle
Great number and fine work on the build
Andy-AMSOIL is offline   Reply With Quote
Old 07-13-2014, 09:40 PM   #14
Ivan @ Southwest Speed
Drives: '15 Z06, '01 NBM SS, '97 SS
Bangin work guys!!!
Ivan @ Southwest Speed is offline   Reply With Quote
