Old 04-07-2012, 07:40 PM   #43
Stealthpanda
Thread Ender
Stealthpanda's Avatar
Drives: 2010 Camaro 2SS/RS L99
Originally Posted by KMPrenger View Post
Not sure about that...Ford seems to be doing awfully well putting out good numbers with the 5.0. Of course, the LS3 may have better mod potential.
GM could do pretty well with something between 5.0 to 5.5 lt especially with Direct Injection.
The thing is, once the weight comes down as it should for the 6th gen, even using the exact same amount of power would be a hell of an improvement. Calling for an SS with nearly 500 HP is really completely unnecessary.
Next ZL1 or Z28 should be the only model needing 500+ HP numbers.
Thats fair enough, nothing wrong with the Coyote engine at all. And yeah, if weight comes down, even to stock 11-12' mustang numbers (what 250-300 lbs lighter?), a 20-25 hp/lb-ft boost across the board will make it look like a rocket. What were the LS1 98-02 Camaros running in there day? Werent they like what 31-3200 lbs? I fully agree weight might mean more than power, in the future.
Stealthpanda is offline   Reply With Quote
Old 04-07-2012, 07:43 PM   #44
Stealthpanda
Thread Ender
Originally Posted by fielderLS3 View Post
The new DI V8 will probably be downsized a little, but not a lot. I can say from experience that the 5.0 Coyote does just fine with its Ti-VCT. Admittedly, it does give up a little low-end torque compared to the LS3, but not much. And it gets 28-29 mpg with the cruise set at 70 on the highway.
And keep in mind that the 6th Gen Camaro will likely be downsized as well. You can be sure that the new DI V8 in the 6th gen will have at least the same, if not better, torque to weight and power to weight ratios.
And again, no hate on the 5.0, although it is a bit lower on torque stock than the LS3 (methinks 395 lb-ft?).
Maybe this is the "ahem" ploy afterall. Start with something amazing to us, the people, and improve on its fuel efficiency, weight, etc for 6th gen.
Old 04-07-2012, 07:43 PM   #45
The_Blur
Moderator
The_Blur's Avatar
Drives: 2018 Harley-Davidson Street Bob
Send a message via AIM to The_Blur
By the way, the rumors have said that any DI V8 will be 5.5L.
Not gonna happen.
Ford didn't so much kill the Ranger. It already died of old age about 10 years ago. Ford just finally pulled the plug on the life support.
Thank you. I was waiting for someone to say it.
Honestly, I don't get this TTV6s replacing V8s. I mean, I understand it from a marketing perspective....people have this notion in their heads that the TTV6 will be greatly efficient, and that V8s are old and wasteful, and in marketing perception becomes reality. And if Ford does it, GM has to do it because of perception alone.
The part I don't get is where are all the benefits for all the cost. From what I can tell, in the real world, downsized and turbo charged engines that maintain the same output of larger engines with 2 more cylinders only offer marginal fuel mileage increases if anything. Certainly not enough to justify the additional upfront cost. And for a buyer like me who keeps his cars for the long haul, the two $1500 each time bombs often referred to as turbochargers waiting for the day to blow a hole in my savings account is unsettling.
I could not possibly agree more with your analysis. Any supercharged or turbocharged V6 will test with a marginal advantage over V8s with similar specs. They will peak at different times, have different redlines, and have other characteristics that make one superior to the other in different conditions. They can appeal to different markets, including different performance markets. Imagine a platform offering a drift-spec, a track-spec, and a quarter mile-spec vehicle, all with different suspension, tuning, and even engine options. The Camaro could be that car one day, especially if GM is working on different performance powerhouses and experimenting with how to make each best.
I also agree with the possibility of failure with turbos. It's obviously far less common with cars built that way than vehicles that were originally naturally aspirated. That being said, parts fail much sooner when tuners and muscle car enthusiasts start taking things apart and putting them back together.
RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
Operation Demon//Buy at Invoice//RACECARWEAR
RESPECT ALL CARS. LOVE YOUR OWN.
warn 145:159 ban
The_Blur is offline   Reply With Quote
Old 04-07-2012, 08:12 PM   #46
invaderzim
invaderzim's Avatar
Drives: 45th SS, '12 ducati 1199 on order
this thread is full of good and informative sounding stuff and all so I hate to dumb it down a bit but.. I'm not even worried about a 6th gen camaro. even number gens have historically been so so and the last one, 4th, nearly succeeded in killing off the model. 1,3 and 5 are the awesome gens. wake me up when 6 passes and 7th gen gets here. that is if 6 can't finish off what 4 nearly did...
invaderzim is offline   Reply With Quote
Old 04-07-2012, 09:23 PM   #47
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by Stealthpanda View Post
Can we just pray its not a drastically lower displacement like the 5.0 DOHC Coyote engine? 6.2L OHC DI pl0x.(says without knowing much about engines)
There is no replacement for displacement, right?
In all likelihood, the next gen family of V8s will be based around 2 displacements, 5.3L and 6.2L. I'd guesstimate that the 5.3's should have comparable numbers to the current LS3, or perhaps a bit lower. In a lighter next-gen car, it should deliver superior performance. Of course ... a 6.2 would produce a lot more power than what is had today (my guesstimates say it should be good for at least 50 more hp over the current 6.2's). That would improve things ... more
And they're (thankfully) supposed to stick OHV's.
Rumours which started because the Corvette LeMans team uses 5.5L engines, but the people that perpetuated the rumour tended to ignore the fact that this displacement is due only to the restrictions in the rule book. Earlier it was 6L, and Corvette racing used a 6L version of the LS7, but the actual production engine remained at 7L. Point being, GM will continue to produce engines in whatever displacement they see fit, regardless of the ALMS rules say for racecars.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 04-08-2012, 09:17 PM   #48
KMPrenger
KMPrenger's Avatar
Its going to fall on the styling of the car....because with the Alpha platform on hand and new engines and suspension technology available or on the very near horizon for GM....I can't see how the car wouldn't perform better than the 5th gen.
Old 04-08-2012, 09:30 PM   #49
Captain Awesome
Originally Posted by zogster View Post
There will be a V8 still, no way they get rid of it. It will be interesting what the model designation is of a twin turbo V6 Camaro though. Surely they won't use Z/28 or SS.
I've been sounding the alarms for a couple of months that the 4-cylinder engine will be in the new RS and the SS will have a V6 and super expensive limited production models like the ZL1 will be the only way to get a V8 Camaro, but I keep getting scolded for saying this because of some forum rules that do not allow criticism of the world we live in.
It's fine for the 500 or so people who can afford a limited production model, but everyone else will just have to make due with what the masses are offered.
Captain Awesome is offline   Reply With Quote
Old 04-08-2012, 09:43 PM   #50
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
If GM thought the market was really that small, they wouldn't even bother with the ZL1 Camaro.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 04-09-2012, 01:21 AM   #51
mexiken
mexiken's Avatar
Drives: Sofia: 2012 Chevy Camaro 2SS LS3
You're lost. On multiple levels.
Interior: 2-tone gray interior, Blue Dome and trunk lights, L.A. Dodgers floor mats (to come: footwell lighting)
Exterior: Sunroof, custom painted gray stripes, vinyl Bowtie emblem decals, Holographic Transformer decals, white license plate LED lights
Sounds: Stock highs, Alpine MRX-M100 amp mated to a 12" JL Audio W3 in a ******** Stealth enclosure
Engine/Performance: Hurst Short Throw Shifter, Rx Catch Can painted IBM, (to come: JacFab CAI, muffler delete/Flowmasters)
mexiken is offline   Reply With Quote
Old 04-09-2012, 01:22 AM   #52
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
LTZ for turbo'd 6?
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 04-09-2012, 06:45 AM   #53
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS
Originally Posted by Bad70supreme View Post
Well they can keep there 6th gen, I will stick with my old pushrod ls3! A turbo v6 is not american muscle it's import talk, not interested. I hope not but the 5th gen could be the last Camaro as we know it, smaller car and a v6, might as well buy a 350z
Right, let's overlook the Turbo Trans Ams... Grand Nationals... I forgot, history only started for you when Fast and the Furious came out, right?
GM has been developing a new DI V8 platform for a while. GM will not ditch the V8 when they have so much technology yet to throw at it to improve performance and fuel economy.
Exactly...
Sorry you lost your credibility when you included 3rd gens in that grouping.
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2016 Camaro 1LT A8 - "Elmo"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 04-09-2012, 08:19 AM   #54
GearBangr
Drives: 97Z,02TA
3rd, 4th, and 5th gens are the best cars in my opinion. They got better and better by the year. Sure the 3rd weren't the fastest, but they brought performance back from the 70s.
I've had 2nd, 3rd, and currently own LS1 and LT1 cars. The older cars don't hold a candle to these. I love classic muscle as much as anyone else, but performance speaking, they're on different levels. Personaly I can't wait to drive an ATS based 6th gen.
GearBangr is offline   Reply With Quote
Old 04-09-2012, 08:52 AM   #55
iHasCamaro
Drives: Silver 2012 1SS
Oh shit if Buick makes a retro Grand National that will be sick. Why haven't they?
iHasCamaro is offline   Reply With Quote
Old 04-09-2012, 10:03 AM   #56
DGthe3
Moderator.ca
DGthe3's Avatar
Why would they is more the question. Luxury sport is the domain of Cadillac, not Buick. If Buick were to venture into that side of things, it would become even harder to create a unique image for the brand. This is also one of the reasons why I'm growing to dislike the Regal GS. While its a good car, its not exactly a good Buick.
I think that if Buick were to have any sort of RWD aspirations, the best way for them to do it would be with something more like a Rivera than a Grand National. A comfortable cruiser, not a high-performance beast.
CAMARO WIKI Tran Wiki 66 04-22-2024 11:41 AM
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ JusticePete Suspension / Chassis / Brakes 111 05-08-2013 10:38 PM
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Dragstrip and Launch Techniques Discussion 3 07-30-2010 12:05 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
