Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Transmission / Driveline
Old 08-17-2016, 09:35 AM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
Camaro 6th Generation Skip Shift Eliminator At RPI Designs
2016-2019 Camaro 6th Generation Skip Shift Eliminator $19.99
Also called CAGS Defeat
Do you hate the 1-4 skip shift installed on your Manual Transmission? This little device will eliminate that annoying issue.
Our Camaro skip shift kit will allow you to disable the Computer Aided Gear Selection (CAGS) feature of your Camaro's 6-speed gearbox. This kit comes with the correct connectors, plugs and seals to protect your wiring harness and CAGS solenoid to allow you to re-connect the harness for full CAGS function if you so desire.
http://www.rpidesigns.com/shop/item....iminator-cags/
RPI Designs is offline   Reply With Quote
Old 06-27-2017, 05:28 PM   #2
srcstc
I Have a question about this... Will the dash still correctly show you what gear you're in? Think I saw in a video that it tricks the car into thinking you're in 4th gear when you're in 2nd? Does that mean the dash will say you're in 4th when you're in 2nd?
srcstc is offline   Reply With Quote
Old 07-03-2017, 10:01 AM   #3
RPI Designs
The HUD will show the correct gear.
