dave@hennessey
Old 07-09-2017, 06:56 PM   #1
Austin48624
Drives: 2011 Camaro SS 6-speed
Question What headers are these?
So, I have a buddy of mine who is gonna sell me these headers. I don't know what brand they are, and neither does he because it was with his car whenever he bought it. Just asking, because Im gonna need to buy some HFC if I get them.
Austin48624 is offline   Reply With Quote
Old 07-09-2017, 07:17 PM   #2
Blade56
Drives: 2010 Yellow Camero w/ Rally Strips
I am not sure, but they will need to be repaired to get the dimples out of the tubes. As this will affect the flow throw those tubes. If these were a correct fit for a Camaro, then they should have not had to been dimpled.
Blade56 is offline   Reply With Quote
Old 07-09-2017, 07:23 PM   #3
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
If you don't know.....how would we?
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 07-09-2017, 07:32 PM   #4
jrhagen
Drives: Camaro
V8
jrhagen is offline   Reply With Quote
Old 07-09-2017, 07:47 PM   #5
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
Only suggestion I have is to try the serial number off the bar code, that might pull up something.
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI
Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018.
Splat is offline   Reply With Quote
Old 07-09-2017, 08:06 PM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
I hope he's basically giving you these. Speed Engineering doesn't even have that bad of welds no do I think they use multiple pipes to create one tube. If I were you I'd stay away from these. If you're looking for some big time budget headers get some Speed Engineering headers with some Texas Speed cats or some Texas Speed headers and get it all at once place.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 07-09-2017, 08:52 PM   #7
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Those dimple look like they are there to clear the steering shaft .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 07-09-2017, 09:50 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Not so fast with that!
Watch this fantastic video by Engine Masters. They test how severely dimpled headers affect performance. You will be very surprised.
As for the 'correct fit' part? I agree. The proper fix for our cars is to loosen the motor mounts and shift the engine over a bit until you have clearance. This is usually unnecessary unless you are installing 2 inch headers, and even then most still don't rub against the steering shaft.
TC, I would avoid these unless you are getting an amazing deal. I didn't notice at first, but those collectors have been cut, repaired, and re-welded. It looks like they did a decent job, but you need to check them in person. Check to make sure it has a merge spike in each collector still and that it isn't damaged or bent. They may have been ball joint or bolted flange type previously. Obviously, we can't tell if they used stainless or mild steel for the repair.
Exhaust Header Bash! Testing Power Loss From Dents - Engine Masters Ep. 4
InFiD3ViL is offline   Reply With Quote
Old 07-09-2017, 11:09 PM   #9
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I was just going to post that same video.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 07-10-2017, 10:36 AM   #10
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
So funny guys, that same video came to my mind! To the OP, I hope your getting a deal, and second don't worry about those dimples at all
2012 ZL1 preproduction car #13
ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet
JBZL1 is offline   Reply With Quote
Old 07-10-2017, 10:51 AM   #11
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Looks like generic Ebay headers to me
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 07-10-2017, 11:47 AM   #12
InFiD3ViL
InFiD3ViL's Avatar
Going to have to agree.
Even the cheaper Manzo and OBX headers have a branded badge plate welded on at least 1 primary.
No way to identify these. That bar code is NOT related to the header. That is for the new collector ends that were welded on.
Old 07-10-2017, 12:32 PM   #13
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
As far as welds go between Speed Engineering headers and Kooks as I have owned both the difference is night and day. Yes I have pictures, does it effect performance not at all well all the non scientific research I have performed. I just didn't like the welds and Speed Engineering was gracious enough to return my money minus shipping cost (that's normal). I do not work for Kooks I just didn't like the welds on the Speed Engineering headers.
I disagree but this is in no way an attempt to be correct. Just a difference of opinion.
Ir0nM4n is offline   Reply With Quote
Old 07-10-2017, 12:38 PM   #14
InFiD3ViL
InFiD3ViL's Avatar
Can't hate on that man, at least you tried, right?
It's the people that bash products that they have zero experience with that drives me nuts.
