02-08-2016, 07:32 PM | #1 |
Drives: 2010 camaro ss Join Date: Jun 2010
Catch can on SLP tvs2300
Is it really necessary or is just a valve cover breather fine? 600+whp
02-08-2016, 08:35 PM | #2 |
It's not necessary.
02-09-2016, 05:23 AM | #3 |
So just a breather? I'm asking because small amounts of oil coming from I guess the rear main seal under wot.
02-09-2016, 11:25 AM | #4 | |
Drives: 2010 Camaro Join Date: Nov 2009
#1. This allows crankcase pressure to always be present and this contributes to ring flutter and poor ring seal and increased blow-by. To vent, pressure must first build and there will always be some seeking to equalize with the atmosphere. #2. Power is lost form the downward stroke of the piston fitting this pressure. #3. When you open the PCV system to the atmosphere you are now illegal for street use in all 50 States. #4. It is critical to retain, and if possible improve on all the functions (and only 1 is pollution control related) the PCV system performs to keep your engine alive and relatively wear free for the duration. When you break the system and defeat proper evacuation you are now allowing the damaging combustion by-products to remain in the crankcase accelerating engine wear. The Elite E2 and E2-X systems with billet CSS (clean side separator) retain a closed emissions compliant system, always pull suction on the crankcase for a more stable ring seal as well as constant evacuation of the damaging compounds you do not want remaining in and accumulating on the crankcase. Either of these systems when used with the check valves will always provide constant evacuation and flushing of the damaging compounds from the crankcase as soon as they enter and are still in a suspended state. Once these settle and mix into the oil, they are mainly there until and oil change. Get the most for your engine by installing an Elite Engineering PCV air/oil separating system. Have more questions? Just ask. There really needs to be more education on the PCV system, proper crankcase evacuation, and all the functions these perform to keep your engine alive. |
02-09-2016, 11:29 AM | #5 | ||
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
02-09-2016, 11:50 AM | #6 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
Here is a picture of my Elite catch can, which I painted to match the color of my car.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
02-09-2016, 01:10 PM | #7 |
So which can should I go with? Will this get rid of the oil leaking from the rear main seal?
02-09-2016, 01:16 PM | #8 |
Philippians 4:13
Elite is second to none in quality, fit/finish, and results as you can see by my video. I'm sure there are others that are good too, but I have nothing but positives to say about the Elite. That would be my choice if I were to do it again. As for your issue... someone else will have to chime in on that. I never had an issue like that.
02-09-2016, 01:49 PM | #9 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Im running Elite as well!
However i did upgrade to the Braided lines and Black AN fittings. Makes it look really sharp. I will have to update photo's soon. |
02-09-2016, 02:49 PM | #10 |
Looks like elite is one of the best ones out there. I had a rx catch can complete package clean side and dirty side offered to me for 329 shipped. Is that a good price?
02-09-2016, 03:34 PM | #11 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
Elite here as well w/ SLP TVS2300. After about a year there was probably ~1.5 ounces of gunk in the catch can. Glad I got it.
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
02-09-2016, 07:53 PM | #12 |
Drives: 2015 1SS 1LE Join Date: Sep 2015
Don't overpay for a catch can. I'm sure everyone will bash my $90 Billet Customs catch can BC-175, purchased from Phastek. But you know what, it catches oil and plenty of it! It's well built and looks great.
02-10-2016, 07:52 AM | #13 |
So all you guys with catch cans only have the basic can or the dual vented can?
02-10-2016, 11:31 AM | #14 | ||
Drives: 2010 Camaro SS (RS LS3) Join Date: Dec 2015
As I plan to install the new style SLP TVS2300 and would love to have the same setup as yours Sent from my Nexus 6P using Tapatalk |
