Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 02-06-2018, 12:01 PM   #1
thebluecamaross
thebluecamaross's Avatar
Drives: 2010 Camaro 2SS/RS ABM
5th Gen Z/28 fascia on 5th gen ZL1?
Hey guys,
I'm thinking of selling my ABM SS to get a 14-15 ZL1.
However I am in love with the z/28 fascia. Is it possible to buy a conversion kit of some sort and put the z/28 bumper on the zl1? I know the rear diffuser can be swapped because they are the same design.
It sounds crazy, I know but I want it that way.
thebluecamaross is offline   Reply With Quote
Old 02-06-2018, 12:04 PM   #2
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
yes, you can switch to the z28 front end but it is a lot of work not to mention you will need front fascia, lights, fog lights, and fenders as well.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 02-06-2018, 12:10 PM   #3
thebluecamaross
Can I use the normal lights that are on the zl1? Or do I need to swap them out for the z/28 ones?
Old 02-06-2018, 12:19 PM   #4
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
There is a design reason why Camaro team did not put the 14-15 refreshed front fascia on the ZL1. The refreshed fascia does not allow for as much air flow and therefore not as much cooling. If you plan to do any kind of motorsport driving such as autocross, HPDE, etc... I would not switch to the 14-15 refreshed fascia on a ZL1.
For headlights if you did the switch you would need to switch headlights as well. The 14-15 headlights are a different housing size to fit behind the refreshed fascia.
Nick S is offline   Reply With Quote
Old 02-06-2018, 12:21 PM   #5
SSEssence
Instagram: Sangstah
SSEssence's Avatar
^correct, the headlights are different as well and the mounting structure.
Old 02-06-2018, 01:42 PM   #6
Mike14bumblebee
Mike14bumblebee's Avatar
Drives: 2014 yellow 2SS/RS
Find someone with an ss, since the only difference is ducts to the breaks and splitter I believe, that wants the zl1 front fascia and swap everything over
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
Mike14bumblebee is offline   Reply With Quote
Old 02-10-2018, 11:51 AM   #7
Little Walter
Drives: ZL1
I know you didn't ask for any opinions, but I would definitely be interested in your ZL1 front fascia, just for a spare. In my opinion the ZL1 front fascia looks much much better than the Z/28 front!
Little Walter is offline   Reply With Quote
camaro, conversion, z28, zl1
