10-12-2017, 10:17 AM | #1 |
Drives: '10 2SS/RS Cyber Gray Join Date: Apr 2017
'10 SS FPCM with 1LE FPCM
Good morning
My fuel pressure control module has gone bad - cause unknown I found another member selling his 1LE fpcm, my question is will the 1LE fpcm work with my SS fuel pump?? any and all input is appreciated.
M6, 376ci, LS3 Top End, Holley High Ram, A little compression.
10-12-2017, 08:14 PM | #2 |
My understanding is the 1LE has a ZL1 fuel pump but only a SS Fuel pump control module.
Orange Krush II
10-14-2017, 03:34 PM | #3 |
Whatever the case, your pump would work with either one. The pump only cares about seeing a DC voltage.
Tags |
1le, camaro ss, fpcm, fuel pump, zl1 |
