Roto-Fab
Old 09-06-2016, 06:46 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Hows my head look
Well I got my head back from the machine shop. They was able to put new seats in and checked it for cracks. Said all was good. I'm waiting on my exhaust valves.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 09-06-2016, 06:53 AM   #2
Badfinger
Badfinger's Avatar
Drives: 2010 2SS
Holy crap how much did they remove???
Badfinger is offline   Reply With Quote
Old 09-06-2016, 06:58 AM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
I just threw up in my mouth...sorry...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 09-06-2016, 07:48 AM   #4
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
Uhhh yeah...........no. I'd be installing a new set of GMPP ported castings or at the very least a clean set of used ones before ever putting that back on.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 09-06-2016, 08:51 AM   #5
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Do not run that head like that.
You have tons of nooks and ridges and peeks everywhere. This is going to cause hot spots and you're going to have serious issues with detonation on that cylinder.
You need to get all imperfections welded in and than the entire chamber will need to be CNC'd after to fix that head properly.
Than you need to mill the other head thats not damaged to match this one since it looks like they milled a TON of the head surface down.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 09-06-2016, 09:23 AM   #6
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
It will run but i wouldn't use it.
JD555 is offline   Reply With Quote
Old 09-06-2016, 10:05 AM   #7
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
My thoughts exactly,all those imperfections will be like multiple spark plugs that go off when ever they heat up enough. A combustion at the wrong time will bend a rod or break a piston do not use the head
davidscamaro is offline   Reply With Quote
Old 09-06-2016, 10:55 AM   #8
Swacer
Drives: 2018 GT350
Was this done by a child?
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 09-06-2016, 11:03 AM   #9
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
You cant be serious, just get a replacement head for crying out loud.
zz430camaro is offline   Reply With Quote
Old 09-06-2016, 11:12 AM   #10
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
I wouldn't have even wasted my money on taking that garbaged out head to the machine shop in the first place. Like said before, you're going to have issues on the cylinder if you use it.
JerTM is offline   Reply With Quote
Old 09-06-2016, 11:32 AM   #11
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Could have been done better.
The heads on my car looked like that. Now you can't tell anything was done and just took .005" off for a clean up pass.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 09-06-2016, 01:09 PM   #12
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
That's insane - are the serious about sending you out the door with that going back on the car? Like it's been stated, that's a nightmare of spark knock waiting to happen. I'm guessing this a boosted car (turbo in the background) - so I'd think you'll compound that issue. Not to mentioned they've easily raised the compression a few tenths. How long till you think you have trouble with one of those seats again?
I'd return your large paper weight and get your money back.
What's the back story on the failure here?
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 09-06-2016, 02:18 PM   #13
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
I agree with him.
It even has dents past the fire ring, or it looks like it in that picture. Not saying it couldn't have been fixed but one new head would have been cheaper than to fix it (the correct way) as they would have to weld it, mill it, and port it. Stock head it just isn't worth it.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 09-06-2016, 02:37 PM   #14
Unreal
Drives: 2006 Z06
Looks like an expensive paperweight.
I wouldn't run that on a bone stock car, let alone something pushing for 1000+.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
