dave@hennessey
Old 12-19-2011, 08:33 AM   #1
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
Clay bar scratches
I clayed my car over the weekend and noticed a few more scratches that were not already there. They appear to be in the clear coat similiar to the swirl scratches i already have. I plan on using a PC or similar tool to remove the swirl marks, however, will it also remove scratches caused by the clay that are in lines (i.e not swirls)?
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 12-19-2011, 08:41 AM   #2
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
The clay caused scratches?
Old 12-19-2011, 08:44 AM   #3
UT-Engineer
Just Cruisin'
Yea i tried to knead the clay after each section to bring out a new clean surface in the clay but it appears i didnt do that well enough. The scratches i found so far are only in one section, the hood, but they are not swirls, theyre lines about 2" long. so far ive seen 3 of them like this. Will the swirl remover take these out?
Old 12-19-2011, 08:50 AM   #4
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
Ah, i see. I have never clayed a car, so I was just curious.
Old 12-19-2011, 08:52 AM   #5
UT-Engineer
Just Cruisin'
yeah was my first time doing it and probably didnt have the right technique. I may have applied too much pressure as well when claying . After watching a few online videos seems like no pressure to very little is the best technique to eliminate scratching.
Old 12-19-2011, 10:38 AM   #6
Nessal
Drives: Exige, Miata, Ghia
Yes, a very common mistake is applying pressure when claying. When I clay, I apply almost no pressure and I make sure the surface stays WET. I just glide it back and forth with the only pressure being the weight of my hand.
Nessal is offline   Reply With Quote
Old 12-19-2011, 10:40 AM   #7
v8
v8's Avatar
Drives: 19 Z06
Good to know
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
2014 Zl1 M6
2014 GT500
2016 Challenger Hellcat M6
www.youtube.com/c/garageking
v8 is offline   Reply With Quote
Old 12-19-2011, 10:50 AM   #8
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
The trouble with clay is it grabs bits and then drags it across the paint. If there happens to be a spec of rail dust there, scratch city.
To get the scratches out, just going to have to start with the least abrasive compound (swirl remover) and if that doesn't get it move up to a fine. I'd suspect it will be at least a fine compound to get rid of the scratches, probably deeper than a typical swirl. And throw the clay in the trash.
I've seen clay used perfectly, no pressure, lots of lube... and cause horrible scratches.... never using the stuff again.
Russell James is offline   Reply With Quote
Old 12-19-2011, 11:04 AM   #9
jmart53
jmart53's Avatar
Drives: 2012 Cruze LTZ RS
waiting for Dylan from Adam's to chime in on this one... I have a clay bar kit and everything but still haven't done it to my baby... will wait for more info
jmart53 is offline   Reply With Quote
Old 12-19-2011, 11:20 AM   #10
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
You need to clean your car first. Then when you clay it you need to have a lubricant like detail spray. Dont apply pressure just small circles. If the scratches are not deep you can polish them out. The biggest mistake is applying too much pressure and not enough lube.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 12-19-2011, 12:30 PM   #11
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
Wash your car well! If you get your drying towel dirty after a wash, wash it again.
If your clay is dirty it will scratch.
If you knead the clay to expose a fresh surface and then apply too much presure, the fresh surface can be pushed away allowing dirty clay to come down and contact the paint.
Keep the surface of the paint lubed with soapy water or detail spray.
Use moderate pressure claying in one direction (straight lines that cross-hatch) at a time over a small area.
I use enough pressure to work the paint but not enough to crack an egg (I'm trying to guess a reference point - dont try to crack an egg on your car lol).
Also peel clay to be used from the whole bar so you're only using a small bit at once and not dirtying up your whole stock. This is debatable but I would personally throw a piece of clay away every 1-2 panels then peel off a fresh piece and continue on - especially for the hood, trunk and tops of quarter panels and fenders where scratches/swirls are readily seen. That can be a waste but I'm paranoid.
Victory Red 1SS/RS Ordered - 8/4/09 & Joined Camaro5.com family
6000, Delivered to the customer - 12/21/09
scythezo6 is offline   Reply With Quote
Old 12-19-2011, 12:36 PM   #12
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
This sums up the procedure you should use when claying a car. You MUST wash your car before claying (I'm sure you already knew that OP) and make sure that your clay bar has been kept in a sealed container of some sort.
Iwantone2 is offline   Reply With Quote
Old 12-19-2011, 01:08 PM   #13
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Some micro marring isn't all that uncommon from claying, but scratches would be unusual. Theres a few potential reasons you'd see scratches:
  • A larger particle was picked up by the bar and went unnoticed.
  • You weren't sufficiently lubing the surface as you were working.
  • The car had previously been treated with a glaze or something to hide the imperfections which was removed by the clay thus showing the defects.
To answer your question, swirls are scratches... very find scratches. They appear in a circular pattern more b/c of the way light hits them and your perspective. Also to some degree from the pattern in which most people wipe a car.
The "new" damage you have, as long as they're fine scratches, should come out just as easily as the swirls. If they're more substantial then it will take slightly more to get them out (more passes with the machine or more aggressive polishing) but they should come out without issue.
Adam's Polishes is offline   Reply With Quote
Old 12-19-2011, 01:26 PM   #14
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
In reading the thread, I didn't see if anyone asked if the OP if he droped the clay he was using and if so, did he keep using the dropped piece? If he did, it would explain the additional damage.
my .02 cents.
WiSSDiver is offline   Reply With Quote
My detail story / clay bar warning? Scorpion6 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 38 05-30-2012 12:09 AM
Clay Bar? Salsa- Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 10-15-2011 09:46 AM
Clay bar, polish, then wax, then pics Dosin Camaro Photos | Spyshots | Video | Media Gallery 4 05-31-2011 03:20 PM
Turtle Ice clay bar kit... AMAZING- on wheels and trim! tjk_art Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 01-05-2011 02:37 AM
