11-29-2013, 03:22 PM | #1 |
∞ Smiles per mile
Drives: 2013 ZL1 Summit White A6 Join Date: Jun 2009
WTH is this gunk in the bottom of my catch can after 8000 miles?
This is the first time that I have emptied the catch can in 8000 miles and it looks like there is water mixed in with the oil. Is this normal?
This remained in the bottom of the can after pouring out the old oil. The oil that I poured out looked fine, just old and brown. Sent from my sofa via Tapatalk
2013 ZL1 #4739
'Heisenberg' Color - Walter White Roto-Fab CAI On Reddit? Check out /r/ZL1/ |
11-29-2013, 03:33 PM | #2 |
Drives: Chevys at the limit Join Date: Nov 2010
In the colder months it's not uncommon to find condensation in the can. What you are seeing is perfectly normal.
Best regards, Tyler 888-308-6007 |
11-29-2013, 09:25 PM | #3 |
Drives: 2013 ZL1 Join Date: Oct 2011
that is water. thank god it is in your catch can and not your pan ha ha.
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
11-30-2013, 08:17 AM | #4 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
It's not water; it's condensation that typically burns away when the engine is running at operating temperature after 30 or so minutes. As mentioned above; it's more common in the winter months. Do you do a lot of short trips with start and stop driving?
11-30-2013, 08:25 AM | #5 | |
BAD ZL1
Drives: 2013 VIN 48 Victory Red ZL1! Join Date: Jan 2012
Condensation can also be defined as the change in the state of water vapor to water/any liquid when in contact with any surface. Technically, it IS water. |
11-30-2013, 08:26 AM | #6 |
Drives: 2011 Camaro V6 Join Date: Jun 2013
Condensation is water. If I understand correctly that is condensation in the catch can, and not something that would normally be in the engine.
11-30-2013, 08:47 AM | #7 | |
11-30-2013, 10:31 AM | #8 |
Drives: 2000 Camaro SS Join Date: Feb 2010
Like has been said, it is normal. Might want to disassemble the can (if you can) and give it a good wipe down.
11-30-2013, 04:41 PM | #9 |
Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
ITS WATER ! plain and simple and when the engine does not get hot enough to burn it off,250 degrees oil temp the vapor goes through the crank case and ends up on the cooler parts of the motor. the vapor cools and ends up as water... all of you guys are correct,have a great day..its normal
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
12-01-2013, 01:05 AM | #10 |
BAD ZL1
I didn't say it started as standing water sitting in the oil pan. Its a product of heating/cooling causing condensation. Its a byproduct of heat/cooling, has nothing to do with the combustion process except the combustion process causes the hot to cold temperature variation.
12-01-2013, 07:12 AM | #11 |
Drives: '12 ZL1 #1609 Join Date: Feb 2010
No use arguing about it. The main thing is its not in your engine.
Life is too short to drive cars that suck.
My build Thread |
12-02-2013, 01:06 PM | #12 |
∞ Smiles per mile
Thanks for all the replies. I cleaned it out and am ready to roll.
2013 ZL1 #4739
