01-14-2017, 10:22 AM | #1 |
Drives: 2017 CAMARO RS Join Date: Feb 2016
Cruising RPMs Question - 6 SPEED
Hey guys
6 months in to the Camaro V6 RS and I'm loving it. Almost good with driving a manual now. What RPMs should I be crusing at? Non Expressway speeds (50mph/80kmh) - I try to keep it at 1500rpm, anything less it feels sluggish. I always go up to 6th gear to get to those RPMs. Expressway speeds (70mph-75mph/110-120kmh) - Usually stays in between 2100-2400rpm. 6th gear. Is this correct or should I be going a bit above 1500rpm at non expressway speeds. Thanks |
01-14-2017, 11:51 AM | #2 |
Drives: 2017 2SS Join Date: Mar 2012
Your fine as long as your just "cruising".
The car really isn't doing much work maintaining that speed and rpm level. But as soon as you need to speed up any, like passing a car or sometimes even a slight uphill grade, you can always shift down to 5th. If your really wanting to overtake someone and punch it, shift down to 4th.
1996 Corvette - LT4
2017 Camaro 2SS 2019 GMC Sierra 2500 HD 2015 Harley Davidson Ultra Limited |
01-14-2017, 09:31 PM | #3 |
Drives: 2017 2SS Hyper Blue Join Date: Dec 2016
1500 RPM is around the most efficient speed for most gasoline engines as long as they have enough torque and the LT1 las lots.
01-15-2017, 08:14 AM | #4 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
It kind of comes back to your expectations of the moment. Running at lower rpms is more suitable for when you're in a laid-back cruising sort of mood, higher rpms fit the situation better when you want (or need) snappier response. Try to learn how to gauge this without having to look at the tach, go by "the feel" instead. Maybe even cover the tach over with a piece of paper or cardboard for a while, and turn the radio down a bit so that the engine sounds will be easier to hear clearly. Norm
'19 WRX 6M (the family sedan . . . seriously) |
01-15-2017, 06:36 PM | #5 |
Good idea. I'll give that a shot
