Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 01-03-2018, 02:22 PM   #1
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Question Do 5" Intakes Really Work...?
People often ask us to do tests of our 5" LSA intakes to see if they really do gain power over another intake or even a 4.5" Intake.
Well instead of being accused of biased test results, we decide to let other shops, other tuners and our customers vouch for their personal results.
So... do they work?
You be the judge.
The filter sits right behind the factory brake duct for increased airflow to the high flow K&N filter and illuminating the need for a airbox in your engine bay. And reducing the amount of hot air sucked up by the intake.
(Filter shown installed on a lowered CTS-V, Providing more than enough ground clearance for people worried about sucking up water going through a large puddle)
Not only have we seen power increase over 4.5" intakes, but our RPM 5" intake is the only 5" intake on the market that allows you to customize your options from PCV fittings to Meth & IAT bungs.
We also provide an intake coupler for use on stock throttle bodies or larger 102 throttle bodies.
- Black Wrinkle finish
- MAF Flange
- High Flow Green Filter
- High temp Silicone Hose
- 5" Hose Clamps
100% Made in the USA (In house at RPM)
(AIT & Meth Bungs are optional add ons)
Order Now
Still not convinced ... try one for yourself.
Frans96ss is offline   Reply With Quote
Old 01-03-2018, 08:07 PM   #2
d454brisson
Drives: 2014 ZL1
Interesting for my next upgrade but touch pricey
d454brisson is offline   Reply With Quote
Old 01-04-2018, 12:12 PM   #3
kmkalkhoff
Drives: ZL1
Umm yea I would say it works. I put this intake on my 2013 ZL1, which currently holds the SBE boost only 5th gen record. It also fits with the largest volume (1.7 gal) under hood tank available for the 5th gen ZL1, which is made my BMR.
kmkalkhoff is offline   Reply With Quote
Old 01-04-2018, 08:23 PM   #4
d454brisson
Drives: 2014 ZL1
Would love to get up there for this intake and a dyno tune
Old 01-05-2018, 01:00 PM   #5
Frans96ss
Frans96ss's Avatar
Drives: 96SS
give us a call we'll get you set up
302-798-4000
Old 01-05-2018, 01:02 PM   #6
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Awesome to hear!!
As we know dyno numbers are only part of the equation, how it performs at the strip and on the street is the other half.
Old 01-05-2018, 01:43 PM   #7
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
Those are nice numbers for sure. I may get one just to see what it does. I have the ADM race CAI and rotofab big gulp now and those have worked well.
I do have an aeroforce air temp sender and would like to add that to the tube. Not sure if a bung is available for that.
My LSA is ported to a 90mm snout so not stock 87mm and no intention to go NW 102.
Sounds like I may need to evaluate this one like I’ve done other products ;o)...
Road Racer here ;o)
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 01-11-2018, 10:38 PM   #8
QUICRNU
Drives: Z06 wannabe
Road Racer here ;o)
-Don
Buy 2 Don, and I will get you some Strip Data
Apex Focused
QUICRNU is offline   Reply With Quote
Old 01-11-2018, 11:03 PM   #9
hammdo
hammdo's Avatar
Ha, ha. Sure ;o) I’ll need to see when I can get one to test and get some numbers from Ryan. Looks promising...
-Don
747 RWHP 794 RWTQ
Old 01-15-2018, 07:26 PM   #10
mmiiller
Drives: 2015 ZL1 Bright Yellow
mmiiller is offline   Reply With Quote
Old 01-15-2018, 07:34 PM   #11
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
Is this the only intake on market to fit the 102 mm TB? im looking for one, since i have a Vmax and CAI set up but ill be getting stuff ported for a 102 TB, what about rain and water, will this be an issue driving in rain, daily driving? Water suction, does it fit the stock MAF sensor , curious about this intake. Also what about the wind shield wiper fluid container.
Hellfighter is offline   Reply With Quote
Old 01-16-2018, 04:17 PM   #12
Frans96ss
Frans96ss's Avatar
Drives: 96SS
The bottom of the filter sits over a foot off the ground and the filter is 9 inches tall. So really unless you drive in 2 feet of water it isnt an issue. Yes fits stock maf sensor. Windsheild fluid containter is moved and replaces with a rotofab which we also sell.
Old 01-28-2019, 04:33 AM   #13
@ReaperZL1
Drives: 2013 camaro zl1 aka the Reaper
i need a way to test this against my jlt CAI with my mods. this thing is nasty already and comes carbon fiber though. if you offered a carbon fiber version, i would be on it like white on rice
@ReaperZL1 is offline   Reply With Quote
Old 01-28-2019, 04:34 AM   #14
@ReaperZL1
hey is this still the record? looking for a goal to achieve
5" intake, cts-v, lsa, rpm 5 inch, zl1
