07-16-2015, 08:35 PM | #1 |
Drives: 2010 Camaro RS/SS AGP Twin Turbo Join Date: Jan 2015
Gas attendant put 87 octane in my car (LS3)
Just as it says, the Gas attendant when I filled up put 87 octane in my car instead of 93 like I asked. It got about 15 gallons in when I noticed and jumped out of my car and shut it off. Then filled it the rest of the way with 93 octane. I got the car home but should I siphon the gas out? Not sure if 87 will just add a knock then I just go back to 93.
Lesson learned, never letting anyone else put gas in my car. |
07-16-2015, 08:37 PM | #2 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
oy... suck/siphon that crap out, refill with high octane. Pull the fuses...
07-16-2015, 08:38 PM | #3 |
Got a link for this fuse pull trick?
07-16-2015, 08:39 PM | #4 |
Dude your car is going to blow up now .
Really My Motorcycle has higher compression than your car and will run just fine on 87 and my bike does require 93 or higher octane . Just don't beat on your car while you use this tank of fuel up .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
07-16-2015, 08:40 PM | #5 |
even better;
#5 and #20... let the car sit like 6hrs +; |
07-16-2015, 08:40 PM | #6 |
Drives: 2014 Z/28 #398 Join Date: Dec 2014
Gas attendant.............. Last one I saw was in 1981
07-16-2015, 08:41 PM | #7 |
07-16-2015, 08:42 PM | #8 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Its the law in certain states.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
07-16-2015, 08:43 PM | #9 |
07-16-2015, 08:45 PM | #10 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
It's ok. Stay out of WOT. Start mixing the real stuff at 1/2 tank or less. It's ok.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
07-16-2015, 08:47 PM | #11 |
Didn't have to ask. Turnpike for the loss.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
07-16-2015, 08:48 PM | #12 |
Pulled the fuses to be safe. I'm gonna try to siphon most of it out tomorrow. Thanks for all the help. Knew I could count on all of you.
07-16-2015, 08:49 PM | #13 |
Why bother? Are you heavily modded? It's ok if the answer is no.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
07-16-2015, 08:52 PM | #14 |
