04-30-2013, 03:04 PM | #1 |
Drives: 2010 ss Join Date: Feb 2011
Superchargers
I'm thinking about supercharging my Camaro.
I have a 2010 2SS , L99 with approx. 2500 Mi/4000 Km. Borla Lt headers and exhaust, Air box and T1000 programer. I'm leaning towards an under hood roots/Eaton stye Magnacharger, E-Force or other. A local reputable shop (Dyno equipped) is recommending a centrifugal Procharger on the premiss that the roots styles are ripping off tires especially with the automatics because of boost range. I'm just looking for a very quick street car, not into competition yet. Any and all comments, advice, opinions, direction will be very appreciated ! THANK -YOU. |
04-30-2013, 03:07 PM | #2 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
The SLP 2300 is an excellent blower. I've never heard that about a roots type. They might be BSing you. Welcome to C5.
04-30-2013, 03:09 PM | #3 |
Welcome to C5! I can't help you with you questions but there are some VERY knowledgeable folks here who, I sure, will advise you. Good luck!
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
04-30-2013, 03:11 PM | #4 |
Drives: 98 Brickyard,The latest THR build Join Date: Jul 2008
We also recommend the SLP.
04-30-2013, 03:26 PM | #5 |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
I just did the New SLP TVS 2300.
With your L99 and mods you would be looking at roughly 500rwhp on a safe tune!
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
04-30-2013, 03:28 PM | #6 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
I recommend the ProCharger D1-SC.
Padre |
04-30-2013, 03:57 PM | #7 |
Drives: ABM SS/RS Join Date: Sep 2009
Have a 2009 Pontiac G8 GT (auto) with a Procharger D1-SC (715rwhp) and a 2010 Camaro SS M6 with a Whipple 2.9 (657rwhp)
I can assure you both will smoke the tires if you get into them! I like both and believe it just comes down to your preference. That being said the Whipple is a twin screw blower which is a bit more efficient than an Eaton style Roots blower. I did my research on that piece of info. Enjoy your build |
04-30-2013, 04:29 PM | #8 |
Stroked and blown
They all smoke tires lol. Roots style blowers give you more boost down low. Probably what your tuner was talking about. They are all good, don't think you can make a bad choice. I will throw my 2 centz Maggie's way.
Enjoy
LME 416 LS3 shortblock/Callies Compstar 4340 4"crank/Callies 6.125 H beams rods/Wiesco 4.07 forged pistons/Cam Motion custom LS1/LME ported heads /maggie TVS2300/I West 8rib 10%OD /3.2 pulley/OD cog drive/JRE tensioner/ID850 /ADM dual fuel/Kooks LT 1 7/8/magna flow2.5 /cat delete/Roto Fab CAI /MGW short throw /SPEC super twin clutch/G Force built trans,carbon syncro rear shaft upgrade /DSS 9"single CF DS /Strange 3.70/31 spline trutrac/MT DR's/earls oil cooler /tuned KHC
04-30-2013, 04:47 PM | #9 |
Drives: Supra searching :] Join Date: Feb 2013
twin turbooooooooooooooooo
04-30-2013, 04:56 PM | #10 |
Anabolic Connoisseur
Drives: Sold - Blown Camaro 2SS/RS LS3 Join Date: Sep 2010
I went with the Maggie as well. Either way you cant go wrong. Like others have said, it all comes down to personal preference.
04-30-2013, 05:04 PM | #11 |
Drives: Florida Speed & Power Join Date: Jan 2011
By ripping off tires I assume they mean you are spinning all over the place? Plenty of cars run the roots or twin screw without issue. I personally like a centri, I like to be able to drive around like its not there but when I want it it screams to life.
I was pushing 700+ @ the wheel on my DD with the ECS SC. Any kinda FI is an improvement over stock. For me, driveability was key, so a centri (ECS-Paxton) was the one I went with and I couldnt be happier. |
04-30-2013, 05:09 PM | #12 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Roots type do produce more TQ down low off idle.
D1sc's are more linear, they are all gonna burn up those tires.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
04-30-2013, 06:20 PM | #13 |
700RWHP-650TQ
All tires can be changed to prevent "ripping them off"
My P Zeros were junk with the Supercharger. Switched to VReds and have had zero traction issues.
04-30-2013, 06:28 PM | #14 |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
I can drive that way with my Maggie, even with 4.10 gears-- just gotta be easy on the throttle (<20% or so, so the bypass valve stays open and doesn't create boost, but push it just a little bit more and the instant torque is there; love it! ).
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq Last edited by fldrummer; 04-30-2013 at 06:31 PM. Reason: typo |
