Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 09-21-2017, 01:13 AM   #1
Spurshot
Drives: 2014 2SS blue
New Skins
I finally couldn't wait any longer. The old OEM Pzeros were hard and worn to the bars and beyond.
These new Michelin Pilot 4S tires are rated the highest in the Max Perf Summer tires by Tire Rack. I found some time this afternoon to get to the tire store and have them mounted. But no time to drive them hard yet. Michelin doesn't make 245/45-20 and 275/40-20 sizes in this model of tire. So, I chose a 255/40 front and a 285/35 rear. This reduced the diameter down to about 28", from 28.7". They seem to fit nicely on the stock 8" and 9" wheels.
Spurshot is offline   Reply With Quote
Old 09-21-2017, 10:00 AM   #2
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
OU812.. nice! they look great!
DvKillar is offline   Reply With Quote
Old 09-21-2017, 10:05 AM   #3
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Bet it rides like a dream, huh!
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 09-21-2017, 04:18 PM   #4
Spurshot
Let's face it, an SS never rode like a dream. I drove it two miles home. I'm sure it rides better than a 1LE or Z. But it does have 3/8" less sidewall than stock SS tires. I believe the rears are the same size used on the front of ZL1 and 1LE.
Old 09-21-2017, 05:02 PM   #5
warnerwh
Drives: 2013 Camaro 2SS/RS
Remember tires are slick when new. Takes a 100 miles or so to get them to where their traction is optimal.
warnerwh is offline   Reply With Quote
Old 09-21-2017, 08:12 PM   #6
Spec
Drives: 2010 Camaro 1SS LS3
Good looking tire!
Though I'm still highly recommending that Nitto NT555 G2's... these are
pretty tires and perform great, especially thick (315's). Look into these when looking at your
next set. You will not be disappointed.
Spec is offline   Reply With Quote
Old 09-21-2017, 11:12 PM   #7
Spurshot
Originally Posted by Spec View Post
Good looking tire!
I've read a lot of good about the NT555 G2. The P4S is in the next higher category above the NT555. Both seem to be the top rated in their respective categories. But these categories are based on same size comparison, not dollar comparison.
https://www.thoughtco.com/tire-perfo...lained-3234419
https://tirereviewsandmore.com/top-1...-summer-tires/
Old 09-21-2017, 11:51 PM   #8
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
Good looking tire!
I've heard they suck at the track, have you made any passes on them yet? I was wanting a set!
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 09-22-2017, 09:00 AM   #9
Spec
They hook very well on the street and love the turns through the hills. Haven't ran them on the track yet though so I can't really speak for that.
Old 09-22-2017, 10:45 AM   #10
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
On my Chevy SS I went with the same size as the OP, but mounted the Conti EC Sport. They were a little cheaper than the MPSS, but the ratings just as good with better wet traction. So far they are an awesome tire, and will be putting them on the ZL1 as well.
SlingShot is offline   Reply With Quote
Old 09-22-2017, 11:30 AM   #11
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
I know with autocross and the 1LE most use the RE71R. I plan on using these tires for the track as well. If issues come up I may try the newest Goodyear tires used on the 2017 1LE.
Link to the RE71R
https://tires.tirerack.com/tires/Bridgestone%20Re71r
Ir0nM4n is offline   Reply With Quote
Old 09-22-2017, 12:33 PM   #12
Spurshot
The good and bad is that there are lots of choices. So many choices that it takes a good bit of reading to figure out what to buy for your needs, budget, etc.. There are trade offs too. You can substitute a larger tire that costs less and get performance gains thru size rather than higher tech expensive tires. I looked at getting wheels and getting a less expensive tire. I took the higher tech tire path. I haven't driven it hard yet and don't know if it was worth it or not. I could have bought some tires for almost half of what these cost.
Old 09-22-2017, 07:25 PM   #13
Roasstum1
EbonyCamaro
Roasstum1's Avatar
Drives: Black SS 14
How many miles did you get out of the original tires???? Just curious
Roasstum1 is offline   Reply With Quote
Old 09-22-2017, 08:12 PM   #14
Spurshot
They were at 40k.
