Old 07-17-2017, 06:01 PM   #1
Irace16
Irace16's Avatar
Drives: 2010 1SS RS M6
Got to drive a Ferrari...then my car
So the wife got me a drive a Lamborghini or Ferrari gift certificate for Christmas at the track I used to race at.. Name:  image.jpeg
Way more fun than I thought it would be... Then for an extra $30 they let me have the track for 45 minutes during their lunch break...Name:  image.jpg
My camaro I feel was faster in a straight line, but the Ferrari handled SO much better. It was my first time having my camaro on a track, gotta say it was awesome until I boiled the brakes! Major pucker factor! Once the brakes cooled they started working fine so I could drive it home. Now to schedule a fluid flush somewhere lol
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
Irace16 is offline   Reply With Quote
Old 07-17-2017, 06:31 PM   #2
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Now you know exactly why when people ask what sort of preparation they should do before going to a track day / HPDE, one of the very first things they get told is to upgrade at least the brake fluid with one of the better DOT4 fluids. Followed by higher temperature capable pads. For fluids, that means ATE200, Motul RBF600, Castrol SRF in order of increasing price and periodic maintenance requirements. There are others, those are just the ones I know of offhand.
FWIW, if you've never done a brake job on this car, chances are that the fluid wouldn't have even met DOT3 specs . . . it'll have way more moisture content and a much lower boiling point.
Norm
Old 07-17-2017, 06:50 PM   #3
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
Lucky you to have a wife like that. Awesome gift.
JLSuperfly is offline   Reply With Quote
Old 07-17-2017, 07:30 PM   #4
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
How much does it take to flush and refill a gen5 camaro SS with stock brembo brakes?
Which of these is the best? ATE200, Motul RBF600, Castrol SRF.
And...
What is a good set of rotors and pads for street, strip and track. I DD thing car right now and I have gone 130+mph. I drive sporty.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 07-17-2017, 08:19 PM   #5
Irace16
Irace16's Avatar
Not sure the amount you'd need, but in my experience racing Castrol SRF is the best. I used to boil all the different racing brake fluids and have to bleed brakes between races, once I switched to SRF I never boiled them again. SRF is speedy tho, it was around 115 a quart the last time I bought some. You do need to make a COMPLETE flush when switching, because it's silicon based and bad things happen when it mixes with standard fluids. I will switch to some kind of dot 4 maybe wilwood 600 or something. I don't track much so I won't put SRF in. But I couldn't recommend SRF more for racing
Old 07-17-2017, 09:28 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Ferrari F430, right?
You are lucky man with an amazing wife.
InFiD3ViL is offline   Reply With Quote
Old 07-17-2017, 10:27 PM   #7
Irace16
Irace16's Avatar
Yep,430 and yep, good wife
Old 07-18-2017, 03:12 AM   #8
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 07-18-2017, 04:15 AM   #9
PJMZL1
PJMZL1's Avatar
Drives: 2015 ZL1
Awesome time I bet!
2015 ZL1 M6
PJMZL1 is offline   Reply With Quote
Old 07-18-2017, 04:25 AM   #10
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Did you have an instructor ride along?
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 07-18-2017, 08:04 AM   #11
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
And...
I used a couple of RBF600 bottles the first time. I use the stock pads on the track and like them. The Motive bleeder makes it much easier. About 6 psi and crack the bleeder screws for a slow but constant trickle.
wakespeak is offline   Reply With Quote
Old 07-18-2017, 08:26 AM   #12
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
good information
Ir0nM4n is offline   Reply With Quote
Old 07-18-2017, 08:49 AM   #13
xc_SS/RS
Drives: 2010 Camaro SS/RS
Get the motive bleeder. Soooo easy, you can bleed the brakes yourself in 1-2 hours.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 07-18-2017, 10:58 AM   #14
drbll
drbll's Avatar
Drives: 2022 Camaro Convertible
That looks like WIR! I didn't know they had Ferrari thing there. You have a good wife!
drbll is offline   Reply With Quote
