Old 03-14-2020, 12:28 PM   #1
BiggE3415
Drives: 2011 Camaro SS
Need help with misfire after header install it's not the plugs or wires.
I need help tracking down a misfire. Its only on one cylinder under load. Happened after installing longtube headers and cai. I just got back from my tuner and we can't figure out what's the issue. So far I swapped plug wire and coil to another cylinder, ohm tested the injector and swapped the injector to another cylinder. The problem stayed on cylinder #4. The only things I can think of is a broke valve spring, pcm, or a wiring issue. To my knowledge my car has been unmolested before me. I'm about to do a cam swap but need to track down the problem before moving forward.
BiggE3415 is offline   Reply With Quote
Old 03-14-2020, 04:19 PM   #2
Black 6.2L SS
Black 6.2L SS's Avatar
Drives: 2014 1SS/RS, LS3, NPP
On a prior car years ago I had a problem with one plug wire shorting out on the header. It was noticeable in my dark garage at night. Pop your hood and rev the engine in the dark with the help of a friend. Watch around cylinder #4 and see if the plug wire or voltage is doing anything funky. After I discovered it I ran wire separators which fixed my problem. Easy to rule out.
Black 6.2L SS is offline   Reply With Quote
Old 03-14-2020, 05:01 PM   #3
Navajo
Drives: 2012 SS Vert
I had this problem and it was a cracked spark plug. Couldn’t tell just by looking at it but after I swapped it with a new one, it ran great.
Navajo is offline   Reply With Quote
Old 03-15-2020, 09:46 PM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
You say you swapped the wire to another cylinder but didn't say youdid the same for the plug. I would start there. Compression test next.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 03-16-2020, 05:21 AM   #5
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Try a new spark plug. Did you remove them when you did the install?
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 03-27-2020, 11:42 PM   #6
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
Any codes?
Mouse330 is offline   Reply With Quote
Old 03-28-2020, 07:05 AM   #7
SSammy
SSammy's Avatar
Drives: 2015 2SS A6 Commemorative Edition
I agree with Greenhornet2, compression test next. If that cylinder is low, squirt a bit of oil in it and test it again. If compression gets better with oil, it’s bottom end, if not, it’s top end.
SSammy is offline   Reply With Quote
Old 03-28-2020, 07:25 AM   #8
SSammy
SSammy's Avatar
Black 6.2L SS’s test is good one to try too. When I swapped heads on my 454 and had a miss on startup, shutting off the lights revealed the shorting plug wire
Old 03-28-2020, 07:55 AM   #9
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
pull your spark plugs and look at them. you probably cracked one when installing your tubes.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 03-28-2020, 11:04 AM   #10
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
8 to 5 you have a cracked plug
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
