Old 11-20-2016, 11:37 AM   #1
Agicon1
Drives: 2010 Camaro SS
Help please? 2010 Camaro SS cammed what oil do I use now
Hey guys I have a 2010 Camaro SS cammed and I was told to change my oil to 20w50 VR1 is that true or what can I use because it says 5w30 on my engine but they said since I'm cammed I need to use the 20w50 VR1 any suggestions?
Agicon1 is offline   Reply With Quote
Old 11-20-2016, 01:51 PM   #2
ABM2010RS
Drives: 2010 ABM RS camaro
i use 20w50 race oil in my 1969 camaro high horse power high compression i think it wont hurt to run it all that matters with a after market cam you need a lot of zinc in your oil.i always use royal purple Also 20w50 does not like the cold.
ABM2010RS is offline   Reply With Quote
Old 11-20-2016, 02:32 PM   #3
Kopterman
Kopterman's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Mobil 1. 0W40 as recommended by my tuner.
Kopterman is offline   Reply With Quote
Old 11-20-2016, 04:05 PM   #4
Matt8892
Drives: 2010 2ss RS. White (RIP) 2012 LS3
I've been running pennzoil ultra platinum 5w30 since doing my cam and all is fine
Matt8892 is offline   Reply With Quote
Old 11-20-2016, 05:02 PM   #5
splashlog48
splashlog48's Avatar
Drives: 2011 Green SS M6
Royal Purple 10W40 here
splashlog48 is offline   Reply With Quote
Old 11-20-2016, 05:07 PM   #6
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
5w30 Mobil 1, no problems here.
High ZDDP isn't necessary for hydraulic roller cams
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 11-20-2016, 05:39 PM   #7
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
Strange seen some people say that is not good. The ones on the life of their cam one. Anyway...
Ir0nM4n is offline   Reply With Quote
Old 11-20-2016, 11:35 PM   #8
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Ran VR1 20w50 in both my GTO's ('04 & '06). They did not explode. I think you'll be fine. My personal opinion is to use dino oil in cammed cars. Of course, I use dino in all my cars. But everyone has their opinions.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 11-20-2016, 11:42 PM   #9
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
DO NOT PUT 20w50 in a LS motor not clearanced for it. you should be running Amsoil ZRod 10w30 or Driven LS30. unless your motor was built and the bearings were clearanced to run 20w50 DO NOT RUN IT.
Old 11-21-2016, 10:23 AM   #10
Outlaw77
Outlaw77's Avatar
Drives: 2018 Charger SRT 392 F8 Green
I'm running Amsoil Z-Rod 10w30.
Outlaw77 is offline   Reply With Quote
Old 11-21-2016, 04:00 PM   #11
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Which cam? Cam Motion cams don't need to be babied like rest
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 11-22-2016, 07:42 AM   #12
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Say what?...
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 11-23-2016, 10:28 AM   #13
Avenging Orange
Originally Posted by fldrummer View Post
Say what?...
Old 11-23-2016, 10:42 AM   #14
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
I use rotella 5w40 synthetic change every 5k or little less no oil use or leaks car has 92k cammed at 82k tsp 235 239 cam dod vvt delete
briancamaross is offline   Reply With Quote
