Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Interior Parts & Accessories
Old 11-08-2011, 08:15 PM   #1
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
ABL Light Pipes
As the original source for these has recently dried up, we have found a second source for a very similar product.
We also have a flexible version that can be used for other applications. The minimum bend radius is about 1.5"
Continuous can be free-cut and works well for shorter lengths.
Tuned is for longer lengths and has a special pattern to minimize dimming in the middle. These can be cut, but, equal amounts should be taken from each end.
Expanded can be free-cut and is for flex applications where there are multiple bends which would make alignment difficult.
Sized for no-drill ABL mod (LED's under panel, not behind dash).
Note that 2013+ cars require three holes to be drilled into the dash to pass the LED's through.
Complete Dash Kit - from $71
http://sjmautoprod.com/5th-gen-Camaro-Dash-ABL-Kit.html
Dash Pipe Package - $25
Driver-Side (Continuous, Flex) and Passenger-Side (Tuned, Rigid).
http://sjmautoprod.com/5th-gen-camar...-pipe-kit.html
Driver Side Flex - $9
For those who have rigid pipes and are not happy with the panel fitment.
http://sjmautoprod.com/light-pipes-5mm.html
Door Panels
- Per Door
Top of Panel: Flex, Tuned: $17 (2LT/SS stock setup)
http://sjmautoprod.com/Interior/5th-...Pipes-Top.html
Bottom of Panel: Flex, Tuned: $20 (order both for full-panel lighting)*
* Requires custom door panel
http://sjmautoprod.com/Interior/5th-...es-Bottom.html
Wiring
Dash Harness
T-Tap/Solder: $23
Plug-n-Play: $48 - ZL1 version available upon request
http://sjmautoprod.com/5th-gen-camar...n-harness.html
Standard Color LED's: $12 ea.
http://sjmautoprod.com/5th-Gen-Camar...o-ABL-LED.html
Splitter: $13 ea.
3-Way Splitter (for full door panels): $18 ea.
Pipes For Customizing (all free-cut)
Rigid, Continuous, 39.4" [1000mm]: $12.92
Rigid, Expanded, 39.4" [1000mm]: $14.25
Flex, Expanded, 39.4" [1000mm]: $20
Flex, Expanded, 78.7" [2000mm]: $28.52
Custom lengths can also be provided.
http://sjmautoprod.com/Light-Pipes-5mm.html
Prices do not include shipping.
sjmautoprod is offline   Reply With Quote
Old 11-09-2011, 12:13 AM   #2
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I already have mind done. BUT...I'd LOVE to see one of these in person!
Will you be selling the light pipes with LED's included? ...that match GM's lights?
Or, is it just the light tubes.
BTW, these look MUCH brighter than the GM ones. Is that how they are or is that the LED that makes it look that way???
Last question. Does the back have a ridge which amplifies the light?....like the original Tyco light pipe?
TAG UR IT is offline   Reply With Quote
Old 11-09-2011, 06:01 AM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
Click to view my build thread
The Stig is offline   Reply With Quote
Old 11-09-2011, 07:04 AM   #4
sjmautoprod
Drives: '16 2SS
This is just for the pipe, but, we can get LED's, too.
Not sure how these compare to the originals.
There is a feature on the back for directing the light.
Old 11-09-2011, 07:22 AM   #5
bee sting
bee sting's Avatar
Drives: 1997 30th Ann. Z28 & 2010 2LT RS
bee sting is offline   Reply With Quote
Old 11-09-2011, 07:46 AM   #6
TAG UR IT
TAG UR IT's Avatar
That's the most important part, IMHO....the "ridge" that runs the length of the light pipe. This ridge is what amplifies the light out in one direction from the tube (long ways). That's the part that shines upwards and hits the dash creating the light effect from behind the dash applique. If you've seen the back of any 2LT or 2SS door which has the ABL, you can see the light pipe and see what I mean.
Hopefully....it'll have this. If it does, you are 100% on the right track for ABL to be done the right way!
Old 11-09-2011, 08:12 AM   #7
The Stig
The Stig's Avatar
I have a piece of tyco light pipe in my glove box. I can take a picture to show you what Tag is talking about.
Old 11-09-2011, 08:29 AM   #8
TAG UR IT
TAG UR IT's Avatar
Go ahead and post it. Let's see if that's going to be the same light pipe.
I talked with Brandon Kasprowicz from Digi Key over the last couple days trying to find if they could get the light pipe. He said that it would basically have to be a VERY large order for them to place the order with TC Communications. I wonder if they could even order them....probably not.
Old 11-09-2011, 09:33 AM   #9
sjmautoprod
Drives: '16 2SS
Thanks, but, we have seen the TE light pipe, just not when they were powered.
As I said, these do have a feature for directing the light.
Old 11-09-2011, 03:02 PM   #10
The Stig
The Stig's Avatar
Here you go.
Old 11-09-2011, 03:43 PM   #11
sjmautoprod
Drives: '16 2SS
Yessir, that's it. I'll shoot a similar video later tonight with our pipe.
Old 11-09-2011, 05:06 PM   #12
The Stig
The Stig's Avatar
Can I put my name down for the pre order? I figure I'm going to need like 8 feet.
Old 11-09-2011, 06:43 PM   #13
sjmautoprod
Drives: '16 2SS
Eight feet? Doing multiple cars?
Here's the video...
Old 11-09-2011, 07:12 PM   #14
The Stig
The Stig's Avatar
Here's the video...
I just have some ideas. You said yours is flexible, can you post a video of you bending it?
Who is up for an install day for the dash ABL? (Updated) 2010SSRSM6 USA - California 565 07-10-2012 08:41 PM
Jba catted mud pipes....check engine light on? Camarowguy Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 13 07-23-2011 08:35 AM
WTB: ABL Light Pipe 2058296-1 Tyco irocnroll Interior Parts & Accessories 13 05-20-2011 08:20 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 01:51 AM
ABL lighting and Footwell Light Install? JProberts USA - Mid-Atlantic 3 02-25-2010 10:17 PM
