02-06-2016, 10:36 PM | #1 |
Drives: 2017 ZL1 and 2018 SS 1LE Join Date: Oct 2015
Transmissiom m6 rattle
Do your transmissions emit a constant very faint rattling sound. It dissappears when I press the clutch in and comes back when I let the clutch out. I remember my 2014 SS had the same thing. It is also there when the car is moving.
02-06-2016, 10:45 PM | #2 |
Drives: 2016 camaro ss Join Date: Oct 2015
nothing that you described on my car.
Summit white, 2SS, Ceramic white interior, 6 piston brakes, Black Bowties, 6 Speed,3.9 sec 0to60 NPP,MRC,NAV,RX Catch can
02-07-2016, 07:13 AM | #3 |
Drives: 2016 2ss Join Date: Aug 2015
02-07-2016, 08:28 AM | #4 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
Does the 6th gen have a single mass or dual mass flywheel? In the C4 Vette if you switched out the dual mass flywheel with s single mass unit it would rattle in neutral with the clutch out like crazy. Sounded like you had a bunch of ball bearings loose in the tranny but it was perfectly normal. I've heard a few others say they've heard a rattle under the same conditions that you describe.
02-07-2016, 08:30 AM | #5 | |
02-07-2016, 12:25 PM | #6 | |
02-07-2016, 02:24 PM | #7 |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Get used to it. The rattles have been a a constant characteristic of the Tremec manual transmissions for many years. My C4 vette, C5 Z06 vette, Gen 5 SS 1LE, all sounded the same. Bunch of marbles at idle, push in the clutch and it quiets up. Sounds like the tradition continues in the Tremec 6060 with rev match.
