Old 05-24-2022, 08:00 PM   #15
JSH
JSH's Avatar
Drives: '20 ZLE
Here's WeaponX' pulley table https://weaponxmotorsports.com/blogs...ng-mods-needed
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 05-24-2022, 08:36 PM   #16
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Care to share the cost for this build? If not, totally understandable. In any case, it’s gonna be bad a$$. Also, with all the hype About the oil pumps failing, maybe it would be a wise choice to have them replace it with the Kaytech one while they’ve cut the engine pulled and opened up
SHE'Z 18 is offline   Reply With Quote
Old 05-24-2022, 09:41 PM   #17
Evansa22
Evansa22's Avatar
Drives: HBM ZLE
I'm guessing the shop meant 2.3 upper as that seems the standard, think its about 10% overdrive. I'll second JSH in doing the lower over the upper pulley. Going smaller means you could have belt slip, bigger lower means more meat for the belt to bite on. Plus you get the added benefits of a lower weight balancer. I would port the snout at minimum to get the benefits from the big gulp and 103tb, if not do the whole supercharger if you plan on sticking with it. Add some ethanol and you will get a nice bump in power also
Old 05-25-2022, 08:26 AM   #18
KamZL1
KamZL1's Avatar
Drives: ZL1
Third on the lower, if you are already putting cam you will want to go bigger later on. Lower will be much easier to change out once you want to change boost level plus less belt slip.
KamZL1 is offline   Reply With Quote
Old 05-25-2022, 10:45 AM   #19
Camaroking98
Drives: 2019 ZL1
just a hair under 12k
Camaroking98 is offline   Reply With Quote
Old 05-25-2022, 10:50 AM   #20
JSH
JSH's Avatar
Drives: '20 ZLE
Which performance shop?
'20 ZL1 1LE A10,
Old 05-25-2022, 10:53 AM   #21
Camaroking98
Drives: 2019 ZL1
will i have belt slip at just regular boost levels? im really just getting the smaller pulley so i can make back the 2-3lbs boost i've lost at altitude
Old 05-25-2022, 10:54 AM   #22
Camaroking98
Drives: 2019 ZL1
under pressure performance colorado springs
Old 05-25-2022, 10:59 AM   #23
Camaroking98
Drives: 2019 ZL1
Honestly...would any of you mind hopping on a zoom with me sometime? I'm new to the whole building thing. I'm no mechanic, I just know the mods I went for should be safe and reliable (my goal, no race car or anything) if all the supporting mods are there and installed right. I'd really appreciate it, and could venmo you for your time.
Old 05-25-2022, 11:03 AM   #24
JSH
JSH's Avatar
Drives: '20 ZLE
Would you measure your upper to confirm its size? WeaponX says 2.50" is OEM
'20 ZL1 1LE A10,
Old 05-25-2022, 11:06 AM   #25
Camaroking98
Drives: 2019 ZL1
Car should be entirely stock. Bought it still with the factory powertrain warranty in tact so should be stock. If it was modded at anytime I'm sure my warranty would've been voided.
Old 05-25-2022, 01:16 PM   #26
Camaroking98
Drives: 2019 ZL1
Guy just called back. All parts but the pulley should be in next week. Slated For an Install of mid - late June.
Parts have all the supporting equipment.
He thinks I should be safe running stock boost level with that 2.3
Old 05-25-2022, 06:47 PM   #27
Evansa22
Evansa22's Avatar
Drives: HBM ZLE
Really couldn't answer that for sure, my builder told me lower is better for the reasons stated. You would probably be fine i just can't answer definitively. Car will be a hoot either way. Also that seems to be pretty good price for the mods imo
JSH, almost 100% sure 2.5 is stock size upper because they put a griptec pulley on the blower while it was getting ported and I told them I wanted stock size.
Old 05-25-2022, 06:50 PM   #28
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
You are correct. The 2.5 is stock. I requested stock from Kong and got a 2.5.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
CW3SF is offline   Reply With Quote
cai, cam, headers, mods, street build
