05-08-2021, 03:00 AM | #1 |
Drives: 2013 Chevy Camaro 2SS L99 Join Date: Apr 2021
Hennessey CAI Sound vs Others?
I have a 2013 SS and am wanting a clean looking cold air intake that will also sound good. I’ve read that rotofab, vararaam, and cai are all amazing but I’m not necessarily looking into an increased performance. Can anyone send a video clip of their Henessey cold air intake so I can hear how it sounds? I’ve heard it sounds good but just can’t find a video of it.
05-08-2021, 03:42 AM | #2 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
The Hennessey intake is metal without a heat shield. For the most part it would underperform compared to the vast majority of the other top brands like Vararam and RotoFab.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
05-08-2021, 04:08 AM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
They will all sound/perform similar.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-08-2021, 05:44 AM | #4 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
When I first got my car I bought a used K/N cheap and it was ok but have since bought a CAI.
It looks awesome and sounds good too. It looks like it belongs under the hood on a modern muscle car.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
05-08-2021, 07:14 AM | #5 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
This is the first time I’ve ever seen someone ask about the way a CAI sounds.
05-08-2021, 07:15 AM | #6 | |
Started#gottalovethatblue
My car had a Hennessey CAI on it when I bought it. Unfortunately the previous owner didn’t purchase the heat shield to go with it so the thing was actually a hot air intake because all it was doing was sucking in hot engine bay air. Even with purchasing the Hennessey heat shield it does a TERRIBLE job isolating the intake from the engine temps. There’s a giant hole where the intake tube slides into from the top of the heat shield that doesn’t seal up. If you’re looking for the open air box look, go with Rotofab. Their intakes are top notch and look great. You’ll get better performance as a side effect as well.
05-08-2021, 08:58 AM | #7 |
Drives: 2011 Camaro SS Join Date: Jul 2019
Ive had a K@N cai on my car for 8 years. It was my first mod. It has the chrome tube and looks and sounds great. This subject has been beaten to death. Youre not winning or losing a race because of your choice of intake Buy the one you want..you will be happier.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
05-08-2021, 09:01 AM | #8 |
05-08-2021, 09:18 AM | #9 |
USA-1
If you can hear the intake over your exhaust, you are doing it wrong.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
05-08-2021, 10:05 AM | #10 |
I laugh, but he's right! I happened upon a Mustang the other night. He revved his engine at me real big so I opened my Noweeds diverters and "outdid" him.
05-08-2021, 02:37 PM | #11 | |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
When I ran my k&n I thermal wrapped it (it helped a lot with iat)
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
05-08-2021, 05:02 PM | #12 | |
05-08-2021, 05:27 PM | #13 |
2&THEHIT
05-08-2021, 06:59 PM | #14 |
Tags |
cai, cold air intake, hennessey, sound clips |
