Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 08-29-2018, 06:04 PM   #1
BURNYs
BURN RUBBER NOT YOUR SOUL
BURNYs's Avatar
Drives: 2013 ZL1 M6 Blue Ray
1050X injectors $800
Only 1k miles on them. Went to bigger injector for E85. $800+shipping.
Mods-Kong Ported Blower, ID1700X injectors, 2.35/8.65, TSP Ported Heads, Custom Grind Cam, RPM 5 inch Intake, NW 102mm, Kooks 1 7/8, Corsa Extreme, Afco Heat Exchanger, PNR 4 gal ice tank/EMP pump, Oil catch can, Thermal reduction plates, BR7EF plugs, DSX Aux Pump, Monster LT1-S triple. 788hp/757tq-93, 839hp/785tq-E85. Burn Rubber Not Your Soul
BURNYs is offline   Reply With Quote
Old 08-29-2018, 06:14 PM   #2
Fitelite240
Drives: camaro5
Couple question. These didn't fit your e85 needs because you went over 1000hp I'm assuming?. And do you use a vacuum pump on conjunction with your oil catch can? Also what's the brand of oil catch can? Curious. Thanks.
Fitelite240 is offline   Reply With Quote
Old 08-29-2018, 06:49 PM   #3
BURNYs
BURNYs's Avatar
No I use DSX Aux Pump, so I don't have good enough fuel pressure to use 1050X on 100% E85. Need bigger injector to compensate. It's just a Elite Engineering catch can.
Old 08-30-2018, 11:38 PM   #4
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Id1050x are very good. I am using a ZL1 pump NO bap, DSX auxiliary fuel pump. On 100% VP. E85 (X85) I am at 70% duty cycle at 700 rear wheel horsepower through a TH400.
Truth be told you do not need to run 100% E85. Seems anything over 40% car performs about the same 10 seconds flat @ 135mph. With much lower injector duty cycle.
Slickcas is offline   Reply With Quote
Old 08-30-2018, 11:48 PM   #5
BURNYs
BURNYs's Avatar
Yeah I didn't try different mixtures of e85. I have a 62hp/46tq difference between 93 and e85.
Old 08-31-2018, 01:13 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
DSX aux pump here too, 1050x, E85 (70-80%).
Duty cycle between 75-85% depending on rpm and % of E. Good injectors...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 09-01-2018, 11:06 AM   #7
Ajax2112
Drives: ZL1
What size did you step up to? 1300? I’m having the same problem. I’m at 97% on E85. I want to upgrade so that I have some head room. I don’t like running things on the edge.
Ajax2112 is offline   Reply With Quote
Old 09-22-2018, 07:24 AM   #8
BURNYs
BURNYs's Avatar
Bump $750+shipping
Old 12-26-2018, 11:20 PM   #9
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
Did u ever sell these?
The 2010 Sin is offline   Reply With Quote
Old 12-27-2018, 03:21 AM   #10
BURNYs
BURNYs's Avatar
Sold
